how to hide battery cable - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 22nd, 05, 06:14 PM Thread Starter
I'm relocating my battery to the trunk and would like some suggetions on how to run my battery cable to the starter. Can it be brought in from the rear or does it have to be brought in from the front of the block.
It would be great if I could get some pictures.
Deano
67 camaro 462 BB 9.6 CR Compcams 314HR 252 @ 50 612 lift, Port+Polish Oval port 2.19 1.88, Edelbrock RPM intake, 850 Holley DP, 3" exhaust, turbo 400 TCI 4000 stall, Dana 60 4.10 posi, 315/60/15 BFG M/T drag Radials, 3650lbs. w/driver. [email protected]
CanCamaro is offline
post #2 of 5 (permalink) Old Apr 22nd, 05, 09:02 PM
Bob
Re: how to hide battery cable
I ran mine down next to the rear wheel well and along the pass side channel. I found a bulkhead connector and located it down under the heater core box. Drilled though the floor panel. I terminate the positive on the interior side and on the engine side I connect a small + cable to the starter.Here is a couple of pics
Bob
69vert is offline
post #3 of 5 (permalink) Old May 19th, 05, 03:32 PM
Rod
I also ran mine like 69vert, except I also ran the negative cable to the front. The bulkhead connectors are 1 1/4" diameter and can be ordered from Jegs/Summit for about $9 a piece plus S&H. For the wire I used two 13-14 foot runs of 2 gauge wire I picked up from http://www.quickcar.net/electric/battery.html.
Rod
69 Camaro with LS2/4l70e
Rocketrod is offline
post #4 of 5 (permalink) Old May 19th, 05, 04:38 PM
I was able to put a 90 degree bend on the 1/0 cable end and had the wire routed rearward on top of the starter solenoid and then have it going through the firewall with a compression type of fitting so water doesn't get into the interior.
I had some old 3/4" braided stainless steel heater hoses laying around and was able to get the 1/0 wire inside of it to dress it up.
For the ground I used one of the transmission bellhousing bolts and also ran that wire directly back and through the firewall.
For the wire off of my alternator I routed it down under the headers and used a tapped hole on the block where the factory spark plug heatshields were bolted into and used rubber insulated clamps (Adel clamps) to hold it in place.
Here is a link to a shot of the alternator wire on mine. It's the bottom engine picture and in the picture it's the curved braided line above the A/C compressor and you can see one of the clamps below spark plugs #2 & 4).
http://hometown.aol.com/krystaldesigns/pageB4.html
SOA-Nova is offline
post #5 of 5 (permalink) Old May 20th, 05, 09:20 AM
I ran my cables from the trunk through the floor in the trunk, and then simply followed the fuel line up the inside of the frame rail. The positive cable runs all the way up the frame rail to just behind the pass. side upper arm at which point it goes under the header and hooks directly to the starter. I have a FORD solenoid in the trunk so there is NO POWER going through that cable unless the engine is being started. The positive cable going to the starter is now the only wire hooked up to the starter.
The ground cable follows the positive cable from the trunk, up the frame rail until it reaches the transmission cross-member at which point it cuts over and bolts to one of the bolts on the tail shaft of the transmission. No need to take it any further forward as everything on the engine is now grounded properly, and I also have another ground strap in the trunk running from the negative side of the battery to the metal hinge support. In the engine compartment, I have the ground straps going from the body to the block in hidden, out of sight places.
Using the Ford solenoid in the trunk really adds a good level of protection in that the cable to the battery is only charged during cranking. I run the charging wire from the alternator directly to the junction block on the firewall (also hidden) and then a wire from the junction block back to the battery for charging.
The cable I used to run from the battery to the starter is 1/0 fine stranded copper welding cable. This set up seems to work very well. Having the battery in the trunk, and hiding all wiring under the hood really cleans up the engine compartment, and also adds in weight placement right over that rear tire!
1969 383CI, T-56, 12 bolt-3.31 posi, 13" C5 Rotors, PBR Calipers, rear disc system..
Go69 is offline
Battery cable ? JimM Electrical & Wiring 7 Feb 13th, 05 06:29 AM
Trunk mounted battery cable size. pdq67 Electrical & Wiring 4 Sep 12th, 04 04:18 PM
Original side post battery cable drdave69 Electrical & Wiring 0 Dec 5th, 03 03:18 AM
Battery Cables, Amp Gage, Voltage Gage, Voltage Regulators, Alternators ...oh my!! Robert Stacho Electrical & Wiring 34 May 23rd, 02 01:30 PM
DieHard Security Battery Recall letter No 'E' in Camaro Electrical & Wiring 4 Nov 1st, 01 03:12 PM
