Trun signal brake light problem - Team Camaro Tech
post #1 of 1 (permalink) Old Apr 28th, 05, 10:24 AM Thread Starter
Wanted to know if anybody could help me with my wiring problem. I am on the back end of the restore on a 1969 camaro. I have cleaned up and fixed the wire loom to the lights and alt, along with under the dash. I powered it up to make sure everything was working. when I turn the turn signal to the right all the lights on the dash and extrior blink with the turn signal. when i turn the signal to the left it works fine. All the lights also come on when I push in the brake pedal in. I have a wiring digram for a 1969 camaro and the only two things that I can see that all these systems are connected to is the turn signal switch in the column, and the main fuse panel. Could the turn signal switch in the column cause this problem? Am I heading in the right direction or could it be somthing else.
496hall is offline
Brake light Switch Guido67SS Electrical & Wiring 6 Feb 24th, 04 04:00 PM
Brake Light Fun CamFrk68 Electrical & Wiring 3 Dec 24th, 00 02:29 PM
brake light/parking light JBELL Electrical & Wiring 1 Dec 19th, 00 07:27 AM
turn signal, brake, parking lights no1dc1983 Electrical & Wiring 11 Jul 16th, 00 05:34 AM
fuel problem HELP jokerdwarf Tech 2000 3 Dec 7th, 99 07:41 AM
