Electrical nightmare!!!!! HELP!!!!!!!!!!!!!! - Team Camaro Tech
post #1 of 3 (permalink) Old Apr 29th, 05, 06:46 AM Thread Starter
Unhappy Electrical nightmare!!!!! HELP!!!!!!!!!!!!!!
All lights work on my 73'camaro except passenger side tail light,both 1/4 side markers and the 2 license plate lamps. Any suggestions will be greatly appreciated thanx.
73'camaro,350/400hp,muncie m-21,hurst comp plus,richmond 3.73 10-bolt posi 8.5
libb58 is offline
post #2 of 3 (permalink) Old May 2nd, 05, 04:08 AM
Re: Electrical nightmare!!!!! HELP!!!!!!!!!!!!!!
Your tail lioghts are powered by one wire ( left, right, and sides ). So if you have power to your Left side and not anything else, somewhere between the left and right the wire is open ( broken ). Try taken a jumper wire and run it from the left to the right and if this works trace down the feed wire and find the open.
If does not work make sure you have a good ground.
67 RS/SS 4P car
http://hobbystage.net/camaro/junebug40/
junbug is offline
post #3 of 3 (permalink) Old May 2nd, 05, 02:28 PM Thread Starter
Thumbs up Re: Electrical nightmare!!!!! HELP!!!!!!!!!!!!!!
Thanx junbug!
libb58 is offline
no electrical power 67RS RAG Electrical & Wiring 6 Aug 5th, 04 07:48 PM
My Electrical Upgrades Brian Lewis Electrical & Wiring 2 Oct 25th, 03 05:46 PM
Electrical Drain 67 Camaro RS Electrical & Wiring 5 Jun 26th, 03 03:11 AM
Mystery electrical shutdown 67Gold Electrical & Wiring 8 Mar 25th, 03 05:53 PM
Complete Electrical Outage kyles67camaro Electrical & Wiring 7 May 7th, 02 02:53 PM
