Fuel tank sending unit - Team Camaro Tech
post #1 of 5 (permalink) Old May 2nd, 05, 03:23 AM Thread Starter
Dan
Question Fuel tank sending unit
Does anyone have a proceedure to bench test a sending unit. I am installing a new tank and want to be sure the sending unit is working before I put it in.
1969 Camaro 350 & 1969 Impala SS 427/ 4-speed (restored)
DanBnis is offline
post #2 of 5 (permalink) Old May 2nd, 05, 03:49 AM
Re: Fuel tank sending unit
If you have a Ohm meter hook up the leads to the sending unit and move the float and your meter should move according .
67 RS/SS 350 ( 4P car )
http://hobbystage.net/camaro/junebug40/
junbug is offline
post #3 of 5 (permalink) Old May 2nd, 05, 12:09 PM
Guess
HwyStarJoe's Avatar
0 (zero) ohms empty, 90 ohms full.
HwyStarJoe is offline
post #4 of 5 (permalink) Old May 2nd, 05, 02:11 PM
It sounds like the fuel gauge sending unit is good!
junbug is offline
post #5 of 5 (permalink) Old May 3rd, 05, 04:25 AM Thread Starter
Dan
Unhappy Re: Fuel tank sending unit
Glad I checked. The one I was going to use did not work. I had another one that did work but it did not get the 0-90 ohm reading. It went to about 150. I took the one that did not work apart. There is just a contactor on a slide. Pretty simple, what could be wrong? I tried cleaning it up with a little scotch brite and still nothing.
DanBnis is offline
fuel tank sending unit dusted800 Performance 1 Feb 12th, 05 10:43 AM
Fuel Sending unit testing Tokyo Torquer Electrical & Wiring 19 Dec 14th, 04 07:03 PM
fuel tank sending unit 69nj350 Tech 2003 20 Oct 8th, 03 09:23 AM
Fuel Tank Sending Unit Camaroinaz Tech 2002 6 Oct 4th, 02 07:52 PM
fuel tank sending unit ohm reading. jrenschler Electrical & Wiring 2 Jul 13th, 02 03:13 AM
