Shocking Shifter - Team Camaro Tech
post #1 of 4 (permalink) Old May 2nd, 05, 04:09 PM Thread Starter
Shocking Shifter
Anyone have an idea of what would cause a small tingling shock on your hand while honking the horn and holding the shifter on a 69' Z28. Don't know how long this has been going on cause I usually never honk and shift at the same time. My wheel is a rosewood 3 spoke OEM from classic industries and everything else is stock.
Thanks Steve
burntbunz is offline
post #2 of 4 (permalink) Old May 2nd, 05, 05:49 PM
Re: Shocking Shifter
Your body is becoming the path of least resistance. Every once in a while I will grab a 12V wire behind the dash of a car and have my elbow resting on the shifter mount or something else metal and I can feel a very slight tingling sensation. Some poeple are more sensitive than others.
Since normally the horn wire on the steering wheel connects a ground for the horn relay you may double check to see that the column is grounded good through the mounting bolts under the dash. I have seen some cars with ground straps on the steering coupler (rag) joint.
SOA-Nova is offline
post #3 of 4 (permalink) Old May 2nd, 05, 06:29 PM
if your horn button is metal, it may well be floating at 12v when you are not blowing the horn
post #4 of 4 (permalink) Old May 2nd, 05, 07:57 PM
JohnZ's Avatar
The ground circuit from the horn button to the horn relay goes through the rag joint, either through a copper strap between the upper and lower flanges or through a copper mesh embedded in the carcass disc. If that ground path has deteriorated, the horn button will ground through the next best ground path, which is through you to the shifter lever. Put a jumper wire between the upper and lower flanges on the rag joint and see if it still does the same thing.
JohnZ
CRG
JohnZ is offline
Hurst Shifter Mounting Plate and Linkage Cameron Transmission & Driveline 2 Mar 3rd, 03 07:23 AM
TREMEC 5sp custom shifter available! mjpell Engine 2 Feb 10th, 03 05:28 PM
Muncie and/or hurst shifter trouble. please HELP Marc Engine 10 Nov 12th, 02 10:08 AM
Muncie and/or hurst shifter trouble. please HELP Marc Troubleshooting 0 Nov 10th, 02 01:53 AM
A trick to fix hurst shifter noise/rattles!! cody Engine 2 Feb 6th, 02 03:26 PM
