new harness installed and wont stay started in the run position - Team Camaro Tech
post #1 of 5 (permalink) Old May 2nd, 05, 07:04 PM Thread Starter
well i picked up a 67 rs/ss and put a new engine/front clip wiring harness in and it won't stay running after the crank position is let off to the "RUN/ON "
position,i had no problems before with it ??any help or ides ?
72prostreet is offline
post #2 of 5 (permalink) Old May 2nd, 05, 07:53 PM
JohnZ's Avatar
Re: new harness installed and wont stay started in the run position
Do you have two wires on the coil (+) terminal? Should be one from the "R" terminal on the starter solenoid that provides power to the coil when cranking, and another from the ignition switch that provides power to the coil with the key in "run" position. If the one from the ignition switch isn't connected, it will crank and start, but will die when the key returns to "run".
JohnZ
CRG
JohnZ is offline
post #3 of 5 (permalink) Old May 2nd, 05, 07:54 PM
Are you running an HEI distributor?
If you are, your problem may be that you have the resistive wire going to the distributor which if I am not mistaken is only suppling 9 volts, not the 12 volts that HEI need. The old point style distributors used nine volts EXCEPT when starting when the wire running from the stater supplied twelve volts.
Anyway, just a possibility, IF you have a HEI distrib. and a new OEM type wiring harness.
Hope this helps,
Victor
67 vert
W 2LG 3L 4P
Obxhokie is offline
post #4 of 5 (permalink) Old May 2nd, 05, 07:55 PM
John you type too fast!
Obxhokie is offline
post #5 of 5 (permalink) Old May 4th, 05, 06:20 AM Thread Starter
JohnZ WELL i have it wired correctly(lite white braided and a yellow wire to the positive side and a black to the negitive side ) but i still get no power in the run positon ,i spent about 3 hrs rechecking the connection and tracing the new harness ,and still nothing .....looks like i'll drive the 72 this weekend
at 3mpg i won't be going to far ..lol
