Dash Strap ?? Gen Light On, New Gauges - Team Camaro Tech
post #1 of 5 (permalink) Old Jun 21st, 05, 12:35 PM Thread Starter
Hi,
I posted this question last weekend, but haven't got many responses:
https://www.camaros.net/forums/showthread.php?t=59429
In my searches here I've seen that the "Dash Strap" may be my problem.
Tonight I'll remove my dash pad. Can someone explain this dash strap to me?
1: Will I be able to see if its hooked up with my pad removed?
2: What exactly do I look for and where does it lead too in the dash?
3: Could this be why my gen light is always on and my console gauge lights aren't on and my fuel gauge is pegged past full?
Thanks. Brian
69, 396, 12-Bolt, 4 speed. Restoring as SS clone. Used to be 307, auto, plain jane. Owned since 81.
hairboy is offline
post #2 of 5 (permalink) Old Jun 22nd, 05, 05:05 AM
Re: Dash Strap ?? Gen Light On, New Gauges
I don't know about the dash strap, unless its a braided length of wire with terminals on both ends and yes, it gets grounded.
Having three ground straps on one screw is fine, just make sure the connection is on good metal and have a good return path to the battery.
The gen light not being on. Power to one side of the bulb comes from the ign switch. It appears a brown/white wire supplies power to the fire wall connector. Then, its piggyback to a brown wire and to one side of the bulb. On the engine side of firewall, the same brown continues to the volt reg connector, treminal #4, the right(?) terminal.
The other side of the bulb is a pink wire, as to other bulbs, HOT, OIL, BRAKE, and Lt & Rt turn signal indicators. The source of power comes from a tie-point , then to the Fuse panel and supplied by a pink wire from the ign switch.
Gauge lamps are hooked up to gray (supply) and black (ground).
Hope this helps.
Doing a good job is like peeing in your dark pants you get a warm feeling, but nobody notices
post #3 of 5 (permalink) Old Jun 22nd, 05, 06:56 AM Thread Starter
Okay,
The green wire (amm meter?) from my new harness wasn't pushed in all the way and wasn't connecting to the engine side harness when I plugged it back in. That does tie into the pink wires I believe in the console loop
Fixed that and that took care of the gen light and I did need a new fuse for the inst.
circuit and a bulb in speedo socket, so now all gauge lights work.
I hope my only prob now is, fuel gauge is pegged to full.
Car show this Saturday, fingers crossed.
Thanks, Brian.
hairboy is offline
post #4 of 5 (permalink) Old Jun 22nd, 05, 07:34 AM
Originally Posted by hairboy
Okay, I hope my only prob now is, fuel gauge is pegged to full.
Car show this Saturday, fingers crossed. Thanks, Brian.
Good luck with the car show.
Fuel gauge, redo the ground wire at the tank strap. 0 ohms = empty, 90 ohms = full.
post #5 of 5 (permalink) Old Jun 22nd, 05, 09:38 AM Thread Starter
Thanks Everett,
I'll try that tonight.
hairboy is offline
Added Console Gauges, Now No Dash Lights hairboy Electrical & Wiring 4 Jun 28th, 06 10:45 PM
Check gauges light comes on. Camaro1995 Engine 1 Apr 25th, 06 01:22 AM
dash light? idiot light? susmooch Camaro Tech 1 May 15th, 05 05:12 PM
Removeal of Dash to Replace Gauges no69x-44 Interiors 11 Jun 5th, 04 01:52 AM
Dash Restore and Gauges too no69x-44 Interiors 8 Oct 7th, 03 04:20 PM
