Turn Key Off,Car still runs - Team Camaro Tech
post #1 of 8 (permalink) Old Jul 24th, 05, 06:47 PM Thread Starter
Question Turn Key Off,Car still runs
Car will momentarily stay running for a a couple of seconds when I turn the key off.
What do you think
68 4 speed
Flynn69 is offline
post #2 of 8 (permalink) Old Jul 25th, 05, 12:08 AM
Re: Turn Key Off,Car still runs
Idle speed too high, electric fan backfeeding to keep ignition powered up until it slows down, low octane gas and deiseling ?.
SOA-Nova is online now
post #3 of 8 (permalink) Old Jul 25th, 05, 03:58 PM
Got MSD? If so you may need a diode prior to the regulator to avoid run on.
tmc1stgen is offline
post #4 of 8 (permalink) Old Jul 26th, 05, 05:45 PM Thread Starter
I do have MSD ,MSD Dist., Electric fan ,Electric Fuel Pump.What would be the best solution. ...Eliminate some things.
68 SS 4 speed
Flynn69 is offline
post #5 of 8 (permalink) Old Jul 26th, 05, 05:52 PM
JohnZ's Avatar
Use the diode that came with the MSD unit just for that purpose.
JohnZ
CRG
JohnZ is offline
post #6 of 8 (permalink) Old Jul 26th, 05, 07:33 PM Thread Starter
The MSD came with the car. I have no box or wiring diagram. Where can I get any info on this matter. Thanks Errol
Flynn69 is offline
post #7 of 8 (permalink) Old Jul 28th, 05, 08:06 PM
Try adding some 104 boost to your gas
indyvegman is offline
post #8 of 8 (permalink) Old Jul 30th, 05, 09:43 AM
http://www.msdignition.com/1troub1.htm#runon
You can also download the instuctions for your MSD too,
Greg U
undee72Z is offline
Does "brake" idiot light come on when you turn the key?? dschribs Engine 2 May 22nd, 05 10:02 PM
runs after I turn key off tommyg Performance 13 Mar 26th, 04 01:56 AM
BRAKE lights OUT when USING THE TURN SIGNALS KED67 Electrical & Wiring 5 Jun 26th, 01 04:40 PM
Tail Light Short & Turn Signal Switch KED67 Electrical & Wiring 3 Jun 25th, 01 09:40 AM
engine almost runs after i turn it off rssteve91 Troubleshooting 7 Apr 9th, 01 06:55 AM
