Wiring cd player - Team Camaro Tech
post #1 of 2 (permalink) Old Jul 25th, 05, 11:52 AM Thread Starter
Wiring cd player
i have a 89 camaro and i need a wiring diagram so i can convert the wiring to my nakamichi cd player so i can hook it up
XxxFros7yxxX is offline
post #2 of 2 (permalink) Old Jul 28th, 05, 05:35 PM
Re: Wiring cd player
I take it that you have the factory installed radio at the present time and it has a connector that goes into the radio. You can purchase an adaptor that will plug into this plug and then into your nak. That is the best way to do it. Of course you can cut the wires and then wire in the nak. If you have a voltmeter or test light it is easy enough to find the +12 volt and ground leads to the radio plug. You will also have a lead for lights and then the rest are going to the speakers front and rear. Use a 6v battery and you can use a set of leads to connect to those speaker wires and you will hear a clicking sound from the speaker which will identify if it is front or back right or left. The only other thing you have to do is see if the cone goes out or in so you can phase the speakers correctly. There are diagrams that are available to show the wire colors etc for the factory setup but you have to buy them. So, as I said, best to buy the adaptor. You can get them from any of the car stereo shops around or on line.
Stan
SirKnite is offline
console mounted 8-track player dilemma Indy Z11 Tech 2002 9 Oct 7th, 02 04:25 PM
console mounted 8-track player dilemma Indy Z11 Electrical & Wiring 3 Sep 24th, 02 02:25 PM
engine wiring harness, extra wire? tdpole Electrical & Wiring 15 Jan 30th, 02 05:34 AM
Wiring Diagram ohayden Electrical & Wiring 9 Dec 30th, 01 02:58 PM
Need help wiring 8-track player mhelman Tech 2000 6 Jan 21st, 00 04:47 AM
