Ignition switch?? - Team Camaro Tech
post #1 of 5 (permalink) Old Jul 30th, 05, 12:09 AM Thread Starter
Question Ignition switch??
Ok, I am back again with another crazy question that is baffling me. The car does not turn off when I turn the ignition switch off. I replaced the switch and the same thing still happens. I don't get it. Any ideas??
Heath
-67' in progress - mostly stock, base model, scb 305, edelbrock intake, Hotchkis 2" drop springs, KYB up front, SSBC disc conversion.
camrod67 is offline
post #2 of 5 (permalink) Old Jul 30th, 05, 12:34 AM
Re: Ignition switch??
You have some sort of wiring defect that is causing the "ignitrion circuit" to be energized all the time. You'll just have to track it down. Do you have a voltmeter or test light? Hook to the + side of the coil. If you have power there with the key off, take off the wires and check them. Is there 1 wire or 2? Are they factory wires or added? One possibility is that the yellow wire from the starter is getting power all the time, feeding back to the rest of the circuit. There's lots of other possibilities too tho.
The factory wiring includes the yellow wire from the starter and the white resistance wire, which comes from the firewall connector. Verify that the coil is or isn't getting power from under the hood (disconnect the firewall bulkhead connector and test, too) let us know what you find, and also the state of your wiring ( any modifications or non standard wiring on the coil, points or electronic ignition, msd type box, erc.)
post #3 of 5 (permalink) Old Jul 30th, 05, 08:48 AM
Do you have a MSD ignition box? If so you may need a diode to prevent runon.
Greg U
undee72Z is offline
post #4 of 5 (permalink) Old Jan 11th, 10, 08:47 AM
Kevin
Could BE the ignition switch because there is a slight room for adjustment And IF NOT properly adjusted would or could still be sending power (may not be fully in the off position) ...
kmg1969ss is offline
post #5 of 5 (permalink) Old Jan 11th, 10, 09:02 AM
Bruno
LOL, if you haven't solve that by now... jk.
"Our affair with Camaros is a life sentence without the possibility of parole".
ORENCH is offline
Ignition Switch? Neutral Safety Switch? planejane Electrical & Wiring 10 Jun 17th, 05 05:04 AM
69 IGNITION SWITCH REMOVAL "HELP" 69ssrs396 Electrical & Wiring 2 Jun 7th, 05 09:04 AM
Ignition switch - help on identifying kfinsrud Troubleshooting 5 May 12th, 05 11:49 AM
Ignition Switch VI018DZ Electrical & Wiring 2 Jan 27th, 05 04:13 AM
Starting Issue -- Starts When Ignition Switch is Released from Start to On SteveN Troubleshooting 4 Oct 2nd, 03 05:46 PM
