rear brake light trouble - Team Camaro Tech
post #1 of 6 (permalink) Old Aug 1st, 05, 07:25 PM Thread Starter
Question rear brake light trouble
I need help with left rear brake light - Works fine until right turn signal on - at that time brake light goes out until right turn signal is canceled. Could this be related to turn signal switch? I traced brake wires into turn signal switch.
David Pearson is offline
post #2 of 6 (permalink) Old Aug 1st, 05, 08:00 PM
Bruno
Re: rear brake light trouble
Make sure the rear tail lamp housings are getting the necessary ground. In my case, I welded a piece of wire to the lamp socket, and routed it to good known ground. I was ****ed by dimmed tail lamps and other faults.
"Our affair with Camaros is a life sentence without the possibility of parole".
ORENCH is offline
post #3 of 6 (permalink) Old Aug 1st, 05, 08:18 PM
I put star washers under 2 nuts on each side.
post #4 of 6 (permalink) Old Aug 1st, 05, 08:27 PM
Make sure you have the right bulbs in the socket, they should be model 1157.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #5 of 6 (permalink) Old Aug 1st, 05, 09:12 PM
Farm Boy's Avatar
If the brake and tail lights are working properly the problem is not a bad ground. When you turn on the left blinker the switch disconnects the brake light signal from the circuit and connects the blinker signal. It is quite possible you have a bad turn signal or hazard switch.
Does the front turn signal and dash indicator light up?
Do your hazard flashers work?
Farm Boy is offline
post #6 of 6 (permalink) Old Aug 3rd, 05, 04:56 PM Thread Starter
thanks for all the info. in the process of installing t/s switch
Brake Bleeding the right way WillS Brakes, Suspension & Steering 0 Feb 14th, 05 04:45 PM
Rear brake cylinder question. supv26 Brakes, Suspension & Steering 10 Oct 30th, 04 05:04 AM
Brake light Switch Guido67SS Electrical & Wiring 6 Feb 24th, 04 04:00 PM
Brake Warning Light Problem Rons68 Brakes, Suspension & Steering 2 Jun 17th, 02 05:15 AM
brake light/parking light JBELL Electrical & Wiring 1 Dec 19th, 00 07:27 AM
