1968 - Adding Voltmeter. Need to ask a question - Team Camaro Tech
post #1 of 10 (permalink) Old Aug 1st, 05, 09:52 PM Thread Starter
Question 1968 - Adding Voltmeter. Need to ask a question
Ok. I'm thinking about adding a voltage gauge to my aunt's 68 Camaro. For now it's going to be mounted under the center dash panel above the console. I was wondering; where can I tap/splice from to get a accurite voltage. I was thinking somewhere like the voltage regulator; but i'm not sure. There is already a grommet missing down about between the parking brake and brake pedal that I can route the wires through.
Thanks in Advance!
Riccbhard is offline
post #2 of 10 (permalink) Old Aug 2nd, 05, 12:46 AM
Re: 1968 - Adding Voltmeter. Need to ask a question
the fuse box works just fine for me should be less than .5 volt off
400bird is offline
post #3 of 10 (permalink) Old Aug 2nd, 05, 09:54 AM
Originally Posted by Riccbhard
Ok. I'm thinking about adding a voltage gauge to my aunt's 68 Camaro. For now it's going to be mounted under the center dash panel above the console. I was wondering; where can I tap/splice from to get a accurate voltage. I was thinking somewhere like the voltage regulator; but i'm not sure. There is already a grommet missing down about between the parking brake and brake pedal that I can route the wires through.
Thanks in Advance!
How accurate do you want. The most accurate is way is wired straight to the battery, through a relay thats controlled by the IGN switch. The purpose of a voltmeter is to monitor battery voltage. You can use the IGN terminal at the fuse box but just as 400bird said it will read a little lower, lower yet when the headlights are on, and pulse some when the turn signals are on, all because of voltage drop in the wiring. If you can live with that, then use the fuse box, if not, use the battery through a relay.
Greg U
undee72Z is offline
post #4 of 10 (permalink) Old Aug 2nd, 05, 10:44 AM Thread Starter
That's perfect. I'll use the fusebox.
*riccbhard goes looking for connector that will fit IGN terminal.
post #5 of 10 (permalink) Old Aug 3rd, 05, 12:29 AM Thread Starter
I'm wondering if this quick-disconnect will fit the IGN terminal in the fusebox?
http://www.radioshack.com/product.as...t%5Fid=64-3134
post #6 of 10 (permalink) Old Aug 3rd, 05, 12:54 AM
Yes, the one on the right. You can buy these at auto parts stores too.
Greg U
undee72Z is offline
post #7 of 10 (permalink) Old Aug 3rd, 05, 10:22 AM Thread Starter
Thanks for reply!
I also had another question:
Is it possible to add a tachometer to a stock distributor?
Distributor is still the stock points system. Engine is the stock L6
post #8 of 10 (permalink) Old Aug 3rd, 05, 10:57 AM
It's certainly possible, make sure that you get one with a "number of cylinders" switch.
It'll need ignition power (there is a spare ingition spade terminal on the fusebox) a ground, and the third wire goes to the neg post on the coil.
post #9 of 10 (permalink) Old Aug 3rd, 05, 02:40 PM
Thanks for reply!
A factory tach or a aftermarket tach? Nearly all aftermarket tachs have provisions for using them on 4,6 or 8 cylinder engines. A factory tach, it would have to be a original one for a 6 cylinder which would be almost impossible to find. For wiring to stock points system, tach wire would go to the coil negative terminal.
Greg U
undee72Z is offline
post #10 of 10 (permalink) Old Aug 3rd, 05, 09:18 PM Thread Starter
Cool. That'll be the next project. I need to find a aftermarket tach first; lol .
Tomorrow i'm heading to radioshack to get the quick disconnects.
I'm wondering if this tach will work?
http://www.partsamerica.com/ProductD...tnumber=CP7901
I'd have to go to Advance to get more info on it.
I'm not sure if there is enough room between the Speedo and Fuel gauge for a steering column mounted tach...
The tach may end up on the console. lol
Thanks for the replys!
Non Camaro question which tuner for my trucks? MStennes Bench Racing 5 Dec 6th, 04 09:08 AM
140 AMP Alternator in 1968 wiring question 68SoBe Electrical & Wiring 5 Nov 23rd, 04 12:46 PM
Body/panel primer/paint question.. HwyStarJoe Body Shop 4 Jul 11th, 02 09:19 AM
Short Water Pump long water pump question sik68 Engine 14 Mar 3rd, 02 05:34 PM
Stall information, and cam question KiZile Tech 2000 8 Jun 19th, 01 04:46 PM
