Heater Fan quits when Engine Running - Team Camaro Tech
post #1 of 4 (permalink) Old Aug 4th, 05, 09:46 PM Thread Starter
LB1
My heater fan blows fine when ignition switch is turned to the right (before cranking the starter over) but when the engine is running it stops? What gives?
LB1 is offline
post #2 of 4 (permalink) Old Aug 5th, 05, 01:15 AM
Re: Heater Fan quits when Engine Running
Need more info!!! Yr of car??? AC/ no AC???
Greg U
undee72Z is offline
post #3 of 4 (permalink) Old Aug 5th, 05, 07:23 AM Thread Starter
LB1
Year of Car is 1968 with no air.
LB1 is offline
post #4 of 4 (permalink) Old Aug 5th, 05, 09:46 AM
Check for 12 volts at the heater fuse or the heater fan with the car running. Do other circuits that have power only with the key on work (ie turn signals)? If not, could be the ignition switch.
Greg U
undee72Z is offline
New Heater Core, Now it's Running Hot murrayo Heating & Cooling 8 Sep 10th, 03 05:30 PM
EBAY or Build Balboni Performance 16 Jun 3rd, 03 11:16 AM
running engine thewebb1 Engine 11 Feb 15th, 03 12:09 PM
Changed heater core, now engine warms up differently Cameron Engine 19 Nov 3rd, 02 03:25 PM
engine assembly lube grumpyvette Performance 21 Mar 16th, 02 11:01 AM
