Smoking Red hot wire - Pls check these voltages for charging - Team Camaro Tech
post #1 of 2 (permalink) Old Aug 7th, 05, 07:00 PM Thread Starter
Unhappy Smoking Red hot wire - Pls check these voltages for charging
Hi all TC,
Recently my 69 died and my fusible link wire at the horn relay smoked up. I replaced the horn relay and disconnected the Sun Tachometer I had just hooked up and everything seems OK, but now Im not charging. The Gen lights stays on when key on and running. Here are the voltage readings I get. Can someone tell me if these seem OK. The regulator is new, and the alternator is just a year old.
With the regulator (external) wires disconected, the gen light comes on very dim when I turn the key. Here are the wire readings with the engine off, but key on
Brown wire #4 reads 8 volts when key on
Orange wire # 3 reads 12.5 volts with both the key on and off.
White wire #2 reads 2 volts with both the key on and off
#1 or F wire reads zero volts with both the key on and off
When I reconnect the 4 wire connector to the regulator, I get the following readings at the connector in the back of the alternator:
White wire at back of alternator reads zero volts with the key on and off
Blue wire at back of alternator reads 3.5 volts with key on, zero with key off.
Does all of this seem OK?
efd75 is offline
post #2 of 2 (permalink) Old Aug 7th, 05, 07:26 PM Thread Starter
Re: Smoking Red hot wire - Pls check these voltages for charging
Just a note, when I put back in the old regulator, the blue wire at the back of the alternator reads 11.5 volts with the key on. Remember it reads only 3.5 volts with the new regulator. Do you think this may have caused the alternator to go bad?
efd75 is offline
Horn relay wire became red hot - allmost a fire efd75 Electrical & Wiring 10 Jul 24th, 05 11:45 PM
red hot ballast resistor yellowrallys Electrical & Wiring 9 Jul 7th, 05 07:22 PM
PO 300 301 302 OBD II 3L 4P Bench Racing 9 May 6th, 05 08:02 PM
welding....need help 69ss350camaro Body Shop 3 Apr 3rd, 03 02:20 PM
Expanded MARTINSR Body Shop 11 Jan 15th, 03 02:57 PM
