68 camaro generator light stuck on - Team Camaro Tech
post #1 of 3 (permalink) Old Aug 10th, 05, 07:33 PM Thread Starter
What could cause my generator light to stay on? Everything seems fine?
Bluesdog
bluesdog is offline
post #2 of 3 (permalink) Old Aug 10th, 05, 07:39 PM
Re: 68 camaro generator light stuck on
To light a bulb, you need power on one side and ground on the other. 12v is supplied to one side of the gen light by the ignition switch. The other side is normally supplied with 12v by the alternator/regulator if (and only if) the alternator is charging. 12v on both sides = no light, same as ground on both sides, or either side open (disconnected)
If the gen light is lit when the engine is running, then either:
a: The alternator is not charging
or
b: the wire that should go to the alternator does not get there, and is grounded out as well.
post #3 of 3 (permalink) Old Aug 11th, 05, 04:15 AM
Check the voltage at the battery with the car running at a fast idle, should be 14-14.5 volts. If its only 12 volts, you are just running off the battery. If you have a 1 wire alternator, disconnect the plug at the voltage regulator to make the light go out.
Greg U
undee72Z is offline
Vintage Camaro [email protected] Camaro Nationals shaugs Team Camaro Cruiz-Ins 1 Jan 31st, 05 07:48 PM
1969 Pontiac Camaro! mjs-13 Camaro Tech 16 Jan 8th, 05 08:58 AM
NE Ohio Camaro Club Fall Classic Sept. 18th-19th Richz68 Team Camaro Cruiz-Ins 1 Sep 16th, 04 01:31 AM
The ultimate Camaro MarkM Performance 32 Jan 22nd, 01 04:52 PM
