69 AM Radio harness connectors, what the heck???? - Team Camaro Tech
post #1 of 28 (permalink) Old Aug 12th, 05, 07:18 AM Thread Starter
Send a message via AIM to smith69z
I have verified through searches that the AM ridio I have is correct but out of 3 different wiring harness's I can seem to find the connector that plugs into the back of the radio (4) spade-type connectors. Is there some type of connector that goes on first then the harness plugs in. I even ordered the radio connector from Ricks and nothing fits.
Please help. I can't move forward with other the radio installation.
Thanks as always!!!
69 Fathom Green RS/Z-Endura bumper - Never finished but finally certified.
smith69z is offline
post #2 of 28 (permalink) Old Aug 12th, 05, 10:44 AM
Re: 69 AM Radio harness connectors, what the heck????
The power connector for the radio is not reproduced. Even M&H doesn't have it. The speaker harness for the dash speaker plugs into the connector on the radio, and then the power connector attached to the dash harness plug into that connector.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #3 of 28 (permalink) Old Aug 12th, 05, 11:35 AM Thread Starter
Mark C. I have 3 original harness's and none fit. So if I understand this correctly is that the dash harness & speaker wire plugs into a power connector that connects into the radio. Its that radio connector that is missing and hard to find.
smith69z is offline
post #4 of 28 (permalink) Old Aug 12th, 05, 08:53 PM
Kevin
KevinW's Avatar
Here are the connectors I have. 2 look the same, but 1 is different. What do I have?
Kevin
KevinW is offline
post #5 of 28 (permalink) Old Aug 13th, 05, 06:19 AM
The lower right and top connectors are the dash speaker extension harness. Green and black wires go to the dash speaker. The large connector plugs into the radio and the dash harness power connector (in the top connector) plugs into those two connectors. The other one is the adapter harness for RPO U80 Auxilliary speaker. The small connector on the left (of the three) attaches to the wires from the fader knob that got installed under the tuning knob on mon radios. The front speaker connector attaches to the larger connector (in the center of the three) and the right connector goes into the radio. That connector is also used with an 8 track player when installed with a mono radio.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #6 of 28 (permalink) Old Aug 13th, 05, 05:37 PM Thread Starter
Kevin,
smith69z is offline
post #7 of 28 (permalink) Old Aug 13th, 05, 05:39 PM Thread Starter
Try that again, KevinW, Want to sell or trade for one of those harness's?
smith69z is offline
post #8 of 28 (permalink) Old Aug 13th, 05, 08:46 PM
Kevin
KevinW's Avatar
Don, I thought you were going to ask that. Do you have a small 2 wire connector (yellow and black wire) coming from the new main harness you bought? If so, we can work something out. if not, then we have a problem. I only have 2 of those for my 2 cars.
Kevin
KevinW is offline
post #9 of 28 (permalink) Old Aug 14th, 05, 05:34 AM Thread Starter
Kevin, Yes I do have a yellow/black connector. And it even has power to it. Unlike the rest of my dash :-(
smith69z is offline
post #10 of 28 (permalink) Old Aug 14th, 05, 08:16 AM
Kevin
KevinW's Avatar
Then I have an extra one. it is the lower right hand one in the pic. The green wires go to the speaker. I wont be avail today. I worked an 18 hour day until 2:30 AM yesterday and going back to work in about an hour.
Kevin
KevinW is offline
post #11 of 28 (permalink) Old Aug 14th, 05, 10:10 AM
Gary
69Z28's Avatar
I'm working an AM set up in my 69 as well. Although I'm temporarily using a 70 Chevelle radio I don't have anything to connect to the back of the radio. I do have the black and yellow wires with the connector, but no speaker, or wire and I think the connections on the back of the radio may be different, not sure about that because I haven't even seen what that looks like on a 69 AM radio. What do I need to make connections?
06A 1969 Camaro Z28 711 69 B Black Stripes Console w/tach and gauges
69Z28 is offline
post #12 of 28 (permalink) Old Aug 14th, 05, 11:33 AM Thread Starter
http://www.chevelles.com/radiotech/index.html
Great site for radio info. Will show what the back of the radios look like.
smith69z is offline
post #13 of 28 (permalink) Old Aug 14th, 05, 11:36 AM Thread Starter
Thanks Kevin, Hope you catch up on the sleep. Give me a yell when you can. I'll need to stop over to drop off the HB puller.
smith69z is offline
post #14 of 28 (permalink) Old Jun 2nd, 07, 07:58 PM
Andrew
Andrew69's Avatar
The wiring harness from the radio to the speaker has a green wire and a black wire. Which is the hot wire and which is the ground wire?
Name:	Radio Wiring.jpg
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #15 of 28 (permalink) Old Dec 5th, 07, 07:10 PM
Bob
Kevin, It looks like you are very schooled in the radio and speaker set up for 69's. Can you help me with my issue? I have an original am radio and I have the correct harness that plugs into the radio. The issue that I have is I purchased a 10 ohm original speaker but it has no wiring on it expcept for a short piece of green wire soldered to one of the terminals. I have two wires coming from the harness. Can you tell me where they attach to on the speaker?
Thanks, Bob
69rs/ssconvert is offline
Orig. Radio/8-track Combo 1967 Panther Tech 2003 17 Aug 5th, 08 08:31 PM
Column Harness Connectors Don't Match rando Electrical & Wiring 8 Mar 24th, 05 04:23 PM
making a harness... need connectors jks67SS396 Electrical & Wiring 2 Mar 28th, 03 11:55 AM
69 AM radio harness Gary L Electrical & Wiring 1 Sep 1st, 02 10:29 PM
Universal Wiring harness end connectors? scalise Electrical & Wiring 2 Jul 5th, 01 09:13 AM
