Dome light question - Team Camaro Tech
post #1 of 4 (permalink) Old Aug 13th, 05, 06:14 PM Thread Starter
Craig
Brackneyc's Avatar
Dome light question
Like I don't have enough going already with this car, I am getting the wiring in order before I go any further. I have everything working except the dome light. I am getting nothing at the bulb, and the wiring is just as it was when the car was built. Does the light switch need to be secured to the dash for the dome light to work? Right now it is hanging, like most of the other dash related parts. I have not replaced the door jamb switches yet, but they are here...in a box somewhere.
Any quick checks to see what might be wrong.
Craig
Now you will see that evil will triumph, because good is dumb.
-Dark Helmet
1967 Camaro
1965 Mustang
2007 Mustang
Brackneyc is offline
post #2 of 4 (permalink) Old Aug 13th, 05, 08:12 PM
67 Camaros Rock
Joe Harrison's Avatar
Re: Dome light question
Switches must be there to complete the circuit I think? They must also be grounded I am pretty sure? Got mine working by messing with the switch and getting grounded.
Joe
-Mark Donahue
My 67 Camaro Time Line
Joe Harrison is offline
post #3 of 4 (permalink) Old Aug 13th, 05, 08:25 PM
Originally Posted by Brackneyc
...I have everything working except the dome light. I am getting nothing at the bulb, and the wiring is just as it was when the car was built. ...
You should have 12 volts all the time on the organge wire. The white wire is a ground circuit that goes to the door switches. If the orange isn't hot, you need to trace back toward the fuse block and see where the voltage is getting lost.
dnult is offline
post #4 of 4 (permalink) Old Aug 14th, 05, 10:12 AM
Larry
The cigarette lighter, glove box light, and clock light are on the same circuit. If those work, then obviously the fuse is good. The 10 hole connector by the emergancy brake is the only component between the previously mentioned components and the dome light. You might try there.
Larry
69-er is offline
whats the type of bulb dome light? jigga99 Interiors 2 May 11th, 05 01:56 PM
67 Deluxe Dome Light tbnm234 Electrical & Wiring 9 May 1st, 05 11:41 AM
dome light, etc. 1NAST69 Electrical & Wiring 6 Nov 14th, 04 09:07 AM
parking light question 61z28 Electrical & Wiring 1 Jul 23rd, 04 07:22 AM
67 Brake Light question xprow Electrical & Wiring 3 Mar 24th, 02 01:21 PM
