Any tips to install brake light switch?? - Team Camaro Tech
post #1 of 3 (permalink) Old Aug 14th, 05, 06:52 PM Thread Starter
Angry Any tips to install brake light switch??
How in the world do you install the brake light switch under the dash? Beside working upside down and no room to get the thread started on the adjusting nut this is one of the most frustrating repairs I've encountered. Help, any tips to make this easier would be most appreciated. Thanks.
stmay is offline
post #2 of 3 (permalink) Old Aug 15th, 05, 04:26 PM
Re: Any tips to install brake light switch??
If you know someone small with a good set of hands that's your best bet.
Sometimes using a mirror instead of trying to get your head up there works too.
And sometimes you just have to deal with it. I was working on some dash wiring once and had a trouble light with a steel cage fall on my face while I was working with both arms waaay up there. I couldn't get my arms down and had to yell until my friend pulled it off. I had a nice red checkerboard pattern on my cheek for about a week.
69 RS 355 Tremec 5-Speed 4.11's
12run is offline
post #3 of 3 (permalink) Old Aug 15th, 05, 06:09 PM
click's Avatar
4 seats bolts and the seat comes out to give you lotsa room. I barely fit under there too, its so tight. With no seat, much easier.
click is offline
Generator light problem - coil, HEI module, resistance wire, ignition switch? mr69 Electrical & Wiring 2 May 29th, 04 08:19 PM
Dome light/ Dimmer switch railing68 Electrical & Wiring 3 Oct 18th, 03 08:08 AM
BRAKE lights OUT when USING THE TURN SIGNALS KED67 Electrical & Wiring 5 Jun 26th, 01 04:40 PM
brake light zac braaksma Electrical & Wiring 5 Dec 16th, 00 03:36 PM
brake light switch dblhip Tech 2000 3 Apr 25th, 00 04:25 PM
