found a plug - Team Camaro Tech
post #1 of 7 (permalink) Old Aug 15th, 05, 09:24 AM Thread Starter
mark
found a plug
I was relpacing my firewall pad, and i found a plug up by where the radio would be. since the car had no radio in it when i got it , it might be for that.
it's flat with one lt. green wire, one lt.green with black stripe,and one yellow wire. i checked my assmb. manual could not find that combo.
any help thanks!
68 SS CAMARO 355,victor jr. intake,performer rpm heads,Quick Fuel carb,Isky z-27 solid cam,TKO 600,4.11 12 bolt,Hotchkis springs front & rear,Flowmaster exhst.
blk/gld 68 is offline
post #2 of 7 (permalink) Old Aug 15th, 05, 12:04 PM
Re: found a plug
What year Camaro is this?
The wiring info for my aunt's 89 Camaro is:
--edit link bad---
Info:
Constant 12V+ - Orange
Switched 12V+ - Yellow
Ground - Black
Illumination - Gray
Dimmer - Brown
Antenna Trigger - Pink
Antenna - Right Front
Front Speakers - 4" x 6" Dash
Left Front (+) - Tan
Left Front (-) - Gray
Right Front (+) - Light Green
Right Front (-) - Dark Green
Rear Speakers - 6" x 9" Side Panels
Left Rear (+) - Brown
Left Rear (-) - Yellow
Right Rear (+) - Dark Blue
Right Rear (-) - Light Blue
Riccbhard is offline
post #3 of 7 (permalink) Old Aug 15th, 05, 12:34 PM Thread Starter
mark
Re: found a plug
Riccbhard, it's a 68
post #4 of 7 (permalink) Old Aug 15th, 05, 12:40 PM
Re: found a plug
--edit link bad---
Info:
Ground - Black
Illumination - Gray
Dimmer - Brown
That jives pretty well with my '68. My original speaker and wires were long gone, but the radio power is yellow.
post #5 of 7 (permalink) Old Aug 15th, 05, 12:56 PM Thread Starter
mark
Re: found a plug
Thanks, to both of you! a cd player is going in anyway, but i wanted to know!
post #6 of 7 (permalink) Old Aug 15th, 05, 01:45 PM
Re: found a plug
Your welcome!
It seems like the speaker wire and power wire colors are the same on most GMs. My aunt's Blazer is the same with the speaker wire colors. It's a 98.
post #7 of 7 (permalink) Old Aug 15th, 05, 02:08 PM
Kevin
KevinW's Avatar
Re: found a plug
It is the factory power and speaker plug. This post should help you (there are pics).
https://www.camaros.net/forums/showthread.php?t=62311
Kevin
KevinW is offline
Rotor, #1 plug wire and balancer are not consistant to TDC???? Erik Beckett Engine 10 Sep 16th, 02 07:45 AM
Get angle plug or straight plug for AFR 195s? Luke805 Performance 7 Jul 12th, 02 11:17 AM
spark plug heat range 1slik55 Engine 2 Aug 6th, 01 01:17 PM
Glowing plug wires Joe Harrison Troubleshooting 9 Aug 4th, 01 07:07 AM
spark plug blow by?? maross396 Troubleshooting 3 Feb 15th, 01 09:41 PM
