Horn relay. Is it necissary? - Team Camaro Tech
post #1 of 6 (permalink) Old Aug 15th, 05, 12:34 PM Thread Starter
Is a horn relay really necissary for the horn to work? I rewired a car with an aftermarket wiring harness. I don't need the horn relay for a power source for anyting else, so I got rid of it.
Only need the horn for inspection reasons, and maybe for other rare occasions as the car is not a daily driver by any means. If I just hook the horn up to a hi amp momentary switch, will it work ok?
MarkM is offline
post #2 of 6 (permalink) Old Aug 15th, 05, 12:43 PM
Re: Horn relay. Is it necissary?
The standard wiring put bat power on the relay to blow the horns, and energized the relay by grounding the relay trigger wire in the steering wheel switch.
As long as the switch and wires will handle the current, you could use anything to put power on the horns themselves.... anything except the horn button in the column.
post #3 of 6 (permalink) Old Aug 15th, 05, 01:22 PM
I re-did my 68 with a painless wiring harness and there is no horn relay and everything works good. It is not needed, painless probably uped the gauge of the wire and thought it would be ok.
Keith
ktaylor36 is offline
post #4 of 6 (permalink) Old Aug 15th, 05, 07:38 PM Thread Starter
Thanks!
MarkM is offline
post #5 of 6 (permalink) Old Aug 16th, 05, 09:38 AM
Gary
Thumbs up Re: Horn relay. Is it necissary?
WOW, think of the weight savings.
69 Camaro convertible 327, TH 350, fully restored, well almost.
Gary Dorion is offline
post #6 of 6 (permalink) Old Aug 16th, 05, 12:20 PM
The thicker guage wire might offset it. hehehe
Horn and relay question???? supv26 Electrical & Wiring 2 Mar 22nd, 03 07:55 PM
(Another) Horn Relay Question Desert 68 Electrical & Wiring 3 Sep 2nd, 02 07:24 PM
Horn Relay ' 67 Question kgaffney Electrical & Wiring 1 Apr 1st, 02 03:17 AM
Horn Relay wiring? kknapp433 Electrical & Wiring 4 Feb 6th, 02 12:36 PM
Horn relay problems 69 Blk69 Electrical & Wiring 4 Dec 2nd, 01 05:10 PM
