please help asap! - Team Camaro Tech
post #1 of 5 (permalink) Old Aug 15th, 05, 01:19 PM Thread Starter
Unhappy please help asap!
my car wont start, it seems like a neutral safety switch problem, but everything works all the way to the "out" side of the neutral safety switch, tested it with a volt meter, everythigns good up to there, where does it go after there? i looked over all the main connections, and im gettin power to everythign else, my starter does nothing at all, please help i need my car running for tonight, thanks for any ideas. - derek
silver_streak67 is offline
post #2 of 5 (permalink) Old Aug 15th, 05, 01:31 PM
ZZ_430's Avatar
Re: please help asap!
Is there voltage on the purple wire coming out of the bulkhead connector at the firewall when cranking? Could be a bad connection there.
Have you tried jumping the purple wire to battery cable at the starter?
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #3 of 5 (permalink) Old Aug 15th, 05, 02:18 PM Thread Starter
i jumped the purple and the main wire down at the starter and it cranks over with that, and i tested the purple wire its gettin 9-10 volts with the key in "start" position. the voltmeter in the car says 9-10 volts then too, although nothings happening the starter doesnt even tick like a bad solenoid, im confused now
post #4 of 5 (permalink) Old Aug 15th, 05, 02:31 PM
It sure sounds like nutural safty to me!
blue ss is offline
post #5 of 5 (permalink) Old Aug 17th, 05, 10:21 PM
Larry
I know this is late, but if you have power at the purple wire at the starter, then I think you are right about the starter/solenoid being bad.Larry
69-er is offline
Please help ASAP getting painted on Wed. shockers69 Body Shop 1 May 22nd, 05 12:12 PM
383 rod balancing NEED HELP FAST ASAP!!! Quick_68 Performance 5 Dec 22nd, 02 02:40 PM
Photo's needed ASAP!!! M21 and M20 Scoop69RS-SS Tech 2001 7 Nov 13th, 01 06:03 PM
Need Help ASAP.... Badcaiman Tech 2001 8 Sep 26th, 01 01:31 PM
bumper re-chromer needed ASAP tples69 Tech 2001 5 Sep 14th, 01 11:45 PM
