99 Wiring Diagram Power Door Lock - Team Camaro Tech
post #1 of 2 (permalink) Old Aug 16th, 05, 03:39 PM Thread Starter
Cool 99 Wiring Diagram Power Door Lock
I Have A 94 Camaro That I Install Power Windows And Locks From A 99 Firebird. The Windows Work Fine But The Locks Do Not Work. My Haynes 94 Camaro Book Shows Two Wires To The Door Locks But The 99 Door Locks Have Four Wires. How Can I Get A 99 Wiring Diagram .
Thanks Don
DONZIGW is offline
post #2 of 2 (permalink) Old Aug 16th, 05, 11:59 PM
Re: 99 Wiring Diagram Power Door Lock
These may come in handly:
---1999 Pontiac Firebird Security Information---
Constant 12V+ - Red - Ignition Switch Harness
Starter - Yellow - Ignition Switch Harness
Ignition - Pink - Ignition Switch Harness
Ignition 2 - Brown - Ignition Switch Harness
Accessory - Orange - Ignition Switch Harness (Heat/AC)
Tach - White V6 - Red/Black (-) - V8 Coil or White PCM Firewall
Neutral Safety Wire - Orange/Black (-) - Switch Base of Gear Shift
Brake Switch - Light Blue or White - Brake Switch
Trunk Release - Black/White (+) - Switch or Brown at Blue -Connector on BCM
Trunk Pin - Orange/Black (-) - BCM Blue Connector Passenger's Kick Panel
Parking Lights - Brown (+) - Head Light Switch or Blue Connector BCM
Head Lamp - Yellow (+) - Light Switch
Door Trigger - Gray/Black (-)DR - Black/White Passenger's Blue Connector at BCM
Door Lock - Red/Black (-) - BCM Passenger's Kick
Door Unlock - Orange/Black (-)
Horn Wire - Black (-) - Steering Column or BCM
Windows Up - LF=Blue, RF=Blue
Windows Down - LF=Brown, RF=Tan
---1993-94 Chevrolet Camaro Security Information---
Constant 12V+ > Red > Ignition Switch Harness
Starter > Yellow > Ignition Switch Harness
Ignition > Pink > Ignition Switch Harness
Accessory > Orange > Ignition Switch Harness
Tach > White V6 > Or White/Black (-) V8 At Coil or Distributor
Brake Switch > Yellow > Brake Switch
Trunk Release > Black (+) > Switch or Driver's Kick Panel
Trunk Pin > Gray (-) > Behind left Rear Speaker
Parking Lights > Brown (+) > Driver's Kick Panel
Head Lamp > Yellow > Light Switch
Hood Pin > n/a
Door Trigger > Gray/Black (-) > Driver's Kick Panel
Door Lock > Red/Black > Driver's Kick Panel Reverse Polarity
Door Unlock > Orange/Black > Passenger's Switch is Master Switch
Horn Wire > Black (-) > Steering Column
Windows Up > L=Dark Blue, R=Light Blue
Windows Down > L=Brown, R=Tan
Riccbhard is offline
wiring diagram 94bullet Electrical & Wiring 0 Jul 6th, 04 07:37 PM
Wiring Diagram Camaro RS 1992 damarck Electrical & Wiring 3 Mar 2nd, 04 04:27 AM
good wiring diagram for 69 camaro ms69 Electrical & Wiring 3 Oct 13th, 03 09:31 AM
Wiring Diagram 69 camaro JADHHJR Electrical & Wiring 1 Apr 15th, 02 01:03 PM
Wiring diagram (total) for 2000 camaro rtumb Electrical & Wiring 1 Apr 18th, 00 04:35 AM
