Orange Wire/Purple Wire? - Team Camaro Tech
post #1 of 5 (permalink) Old Aug 17th, 05, 09:03 PM Thread Starter
I am just about through with my 69 (a 16 month adventure). I kept the old wiring harness that was in decent shape. I am hooking everything back up but did not mark the wires good enough when I disconnected them. I have a orange colored wire that comes out of the harness approximately next to the a/c 'shoebox'. I have some wiring diagrams that (I think) indicates that this may be a wire for the interior heat/ac fan (that connects on the firewall). I have that connection with a purple wire on it now. Does anyone know for certain which wire goes where. Both of these wires have a round black rubber connector-end. Thanks for any help. I could have a few other questions before all the electrical works.
69Mike
69Mike is offline
post #2 of 5 (permalink) Old Aug 17th, 05, 09:43 PM
Larry
Re: Orange Wire/Purple Wire?
If it's a heavy gauge purple wire, then it looks like it goes to the blower motor. The only orange wires I can see go to the fan relay that's mounted on the evaporator housing, but they don't have a round rubber connector.
Larry
69-er is offline
post #3 of 5 (permalink) Old Aug 18th, 05, 05:17 PM
Non-A/C cars have an orange wire that goes to the blower motor.
69 RS 355 Tremec 5-Speed 4.11's
12run is offline
post #4 of 5 (permalink) Old Aug 19th, 05, 04:50 AM Thread Starter
Thanks for the responses. We are getting no power to the fan motor or the ac compressor. We can 'jump' these and see that they do work (new compressor, new fan switch). All grounds look good. We think that the electrical connections under the steering wheel may be not quite right. All the fuses in the fuse box are ok and there is an in-line fuse going to a relay on the evaporator box that is also new. I rewrapped the old harness which was in pretty good shape. We are continuing to look for the problem.
69Mike
69Mike is offline
post #5 of 5 (permalink) Old Aug 19th, 05, 08:34 AM
Get ahold of Mark Canning on the A/C wiring, he's the "local expert" That is his user name here.
orange wire? MRCOOL_RSSS350 Electrical & Wiring 12 Jan 17th, 06 11:45 AM
PO 300 301 302 OBD II 3L 4P Bench Racing 9 May 6th, 05 08:02 PM
welding....need help 69ss350camaro Body Shop 3 Apr 3rd, 03 02:20 PM
Expanded MARTINSR Body Shop 11 Jan 15th, 03 02:57 PM
Orange wire on brake pedal swith??? Erik Beckett Electrical & Wiring 7 Jan 19th, 02 04:42 AM
