Probably replacing radio in 68 tomorrow; need help - Team Camaro Tech
post #1 of 4 (permalink) Old Aug 17th, 05, 10:36 PM Thread Starter
The radio that's in my aunt's 68 right now is a Kenwood that's shot (a.k.a dosent work anymore) and the previous owner had installed 4 speakers; FR, FL, RR, RL. I know the speakers work. For now i'm installing the 2-shaft style radio that was in the '89 (not origional; and didnt fit). Where should I get power for the radio? IGN?
Just wondering.
EDIT: Is there are wire that comes from the fuse box for the 'radio' fuse? If so; what color is it and could I use it?
Thanks in advance!
Riccbhard is offline
post #2 of 4 (permalink) Old Aug 18th, 05, 05:12 PM
Re: Probably replacing radio in 68 tomorrow; need help
There should be a yellow 18 gauge wire somewhere near the radio slot in the dash that connected to the original radio. This wire has power in the run and acc key positions. If you need constant power for a clock or station presets the fuseblock has a BAT terminal you can use.
69 RS 355 Tremec 5-Speed 4.11's
12run is offline
post #3 of 4 (permalink) Old Aug 18th, 05, 05:40 PM Thread Starter
Thanks!
How do I get the walnut looking trim thing off so I can get the radio out?
post #4 of 4 (permalink) Old Aug 18th, 05, 07:57 PM
Terry
Two screws at the bottom of the woodgrain dash plate, then it will slide up and off. It's best to attach a bracket to the back of the radio and the other end up to the underside of the dash, near the front speaker area, this really stabalizes the radio--
Terry M.
tmannet is offline
Radio problems 98 Cam Fan Electrical & Wiring 0 Aug 16th, 05 07:12 PM
Satellite Radio Uncle Tupelo Bench Racing 14 Apr 2nd, 05 02:16 PM
Radio question Hobbes9112 Camaro Tech 0 Apr 25th, 04 09:38 AM
Using a new speaker w/ an original 67 radio gwarren Electrical & Wiring 6 Mar 15th, 02 08:32 AM
Radio Dial Illumination Sleepy-69 Electrical & Wiring 13 Jun 27th, 01 07:06 PM
