HEI ignition wire - Team Camaro Tech
post #1 of 3 (permalink) Old Aug 19th, 05, 07:53 PM Thread Starter
bl
Send a message via MSN to bl1work
HEI ignition wire
i'm doing a massive rewire, fuseblock, fuel injection, etc... on my 69 350, ..I installed a HEI distributor on it to replace the points style.... question is, the BAT wire in the cap, (next to the tach wire), does this wire need to go straight to keyswitch 12 volts now? Or does it need some kind of relay etc... probably a dumb question...
thanks,
bl
bl1work is offline
post #2 of 3 (permalink) Old Aug 19th, 05, 08:03 PM
Re: HEI ignition wire
straight to the ignition switched 12 volts. Usa a 12 gauge wire, don't need a relay.
post #3 of 3 (permalink) Old Aug 19th, 05, 09:09 PM Thread Starter
bl
perfect ... thanks
bl1work is offline
PO 300 301 302 OBD II 3L 4P Bench Racing 9 May 6th, 05 08:02 PM
Generator light problem - coil, HEI module, resistance wire, ignition switch? mr69 Electrical & Wiring 2 May 29th, 04 08:19 PM
welding....need help 69ss350camaro Body Shop 3 Apr 3rd, 03 02:20 PM
Expanded MARTINSR Body Shop 11 Jan 15th, 03 02:57 PM
ignition coil +resistance wire getting extremely hot jlighthart Electrical & Wiring 1 Jun 4th, 01 12:57 AM
