Turn signal & tail light not working - Team Camaro Tech
post #1 of 4 (permalink) Old Aug 21st, 05, 05:35 PM Thread Starter
Did a search on this site could not find a similer problem.
The entire turn signal circuit (interior and exteior lights), tail light and after market tach stopped working. Brake lights and headlights work fine. Checked the fuses and they're good. Could it be a bad ground somewhere? Not sure where to start to try to troublshoot this. Appreciate any help. Thank you
68 camaro 327 mostly stock.
SGcamaro is offline
post #2 of 4 (permalink) Old Aug 22nd, 05, 07:14 PM
Re: Turn signal & tail light not working
Using a test light or voltmeter check the BAT, IGN, and ACC terminals on the fuseblock. BAT terminal should have power all the time, IGN with key in run position, and ACC in run or acc key position. If these check out probe the fuseholder clips (not the ends of the fuses) on both ends to see if you have power. The clips can get corroded and even though the fuses are good the circuit will be dead at one end. Let me know what you find.
69 RS 355 Tremec 5-Speed 4.11's
12run is offline
post #3 of 4 (permalink) Old Aug 22nd, 05, 07:26 PM
Check that you have power to the turn signal switch, all lights power are drawn from there. Do you have parking lights, if you do ground circuit should be OK, sounds like possibly the power that goes to the turn signal switch may have been "tapped" for the power for the aftermarket tach. Also check fuses with a meter (not just visually) as I had a few fuses blown far left or right that you could not see, meter said it was bad and after pulling it the metal cap fell off on one side right where it was blown...
Scotts67 is offline
post #4 of 4 (permalink) Old Aug 24th, 05, 07:15 AM Thread Starter
Update - Fuses are all good (checked with a meter). The problem I had was no power to ACC terminal. I traced it back and found problem. Thanks guys for all your help.
SGcamaro is offline
few wiring questions (painless and autometers) tail light harness MY FIRST 69 Electrical & Wiring 5 Nov 3rd, 04 07:36 PM
turn signal cam RKIM 70RS Electrical & Wiring 5 May 21st, 03 10:18 AM
brake light cancels when i put turn signal teSSa Electrical & Wiring 4 Sep 10th, 02 01:25 PM
67 turn signal lights OBNXUS67 Electrical & Wiring 2 Feb 1st, 02 02:14 PM
turn signal, brake, parking lights no1dc1983 Electrical & Wiring 11 Jul 16th, 00 05:34 AM
