Differences in HEI Tach output? - Team Camaro Tech
post #1 of 2 (permalink) Old Aug 22nd, 05, 07:06 PM Thread Starter
Were there different types of Tach outputs ever used in the F bodies 3rd generation cars? I have just installed a new 350 in an 86 and hooked up the factory tach to the standard tach location. Reads high, almost as if the tach is set for a six cylinder. Had 305 with TPI in it originally and its the iroc z model. I am using the HEI that I had in the old vette motor all along. Figured it would simply work and know it has better insides than the one that came out. Runs like it always did but tach is reading wrong. Were there different distributor modules or tach filters used? If I still had the 86 distributor I would change it back for the heck of it, but its gone.
Seem I read something somewhere that led me to believe there was a different distributor called for in 86 and after than in 85 and before. Saw a dividing line somewhere in a catalog, but cant remember where?
May simply be a bad tach anyway.
William van Hulst is offline
post #2 of 2 (permalink) Old Aug 23rd, 05, 02:09 PM
Re: Differences in HEI Tach output?
Need the OE dist for the OE engine, you might try a reman from the aftermarket.
67 Camaro AC tach and HEI AJL Electrical & Wiring 0 Jun 22nd, 05 11:10 AM
Repo tach and HEI distributor dbackse350 Interiors 3 May 14th, 05 09:15 PM
'69 tach w/ HEI , intermittent problem.... 69jbjohn Electrical & Wiring 9 May 13th, 02 10:31 AM
original tach & HEI J85 Tech 2000 4 Nov 3rd, 00 11:09 PM
HEI Tach Connection Trouble Shooting shelbyz28 Tech 2000 7 Aug 18th, 00 08:09 PM
