Where to get power for radio - Team Camaro Tech
post #1 of 6 (permalink) Old Aug 23rd, 05, 07:27 PM Thread Starter
Question Where to get power for radio
Car:
68 Camaro
Today I was able to remove the non-working Kenwood radio. A wire that went to the radio's switched lead was connected to the IGN terminal at the fusebox. The 'always on' wire is drawn from somewhere over by the fusebox.
The radio i'm putting in is a JVC KSR155 (2 shaft radio like the Kenwood one) and I was wondering would it be ok to use the IGN terminal at the fusebox as switched and the always-on lead that is already there?
Thanks!
EDIT: I also discovered 2 little black boxes on the radio's switched power and one on it's always on lead. I've seen these before. What are they and should I connect them to the JVC radio?
Riccbhard is offline
post #2 of 6 (permalink) Old Aug 23rd, 05, 08:15 PM
Gary
Re: Where to get power for radio
I have used the ign post on the fuse box with no problems. You may beable to locate the power feed to the original radio under the dash and splice into that.
69 Camaro convertible 327, TH 350, fully restored, well almost.
Gary Dorion is offline
post #3 of 6 (permalink) Old Aug 23rd, 05, 08:21 PM
there are extra terminals on the fusebox. If you'd rather splice in, the yellow wires a hot with ignition on, orange is hot all the time.
post #4 of 6 (permalink) Old Aug 24th, 05, 02:40 PM Thread Starter
Thanks!
Does anybody know what the little black boxes are that were in line with the radio?
EDIT: I found a yellow wire that is cut off that hangs barely under the edge of the dash to the left of the radio area.
Would a voltage gauge also be ok to connect to the IGN terminal?
post #5 of 6 (permalink) Old Aug 24th, 05, 03:07 PM
The little black boxes are noise suppressors. The yellow wire is your best bet for switched power to the radio because it's live in the "run" and "acc" positions. The "ign" terminal only has power in the "run" position which would be good for the volt gauge.
69 RS 355 Tremec 5-Speed 4.11's
12run is offline
post #6 of 6 (permalink) Old Aug 27th, 05, 02:29 AM
Originally Posted by Riccbhard
Car:68 Camaro
Use the ACC terminal at the fuse box, it is hot in both key on and ACC positions. Use the BAT terminal for a always hot. See my post here for more info and a pic.
Greg U
undee72Z is offline
67 Camaro Power steering gear box pdq67 Brakes, Suspension & Steering 5 Nov 8th, 14 09:14 AM
Fabing power steering lines JamesD Brakes, Suspension & Steering 4 Jan 28th, 04 06:36 PM
bench Bleed M/C and power booster set up? mine_is_blue Brakes, Suspension & Steering 3 Nov 17th, 03 02:23 PM
matching the power curve to gearing grumpyvette Engine 21 Jul 8th, 03 08:15 AM
