riddle me this (hei dist) - Team Camaro Tech
post #1 of 9 (permalink) Old Aug 28th, 05, 12:08 AM Thread Starter
Angry riddle me this (hei dist)
i have a fast burn 385 with hei dist. i am runnin the power wire to a yellow wire on the wiper motor would this cause the wiper motor to get really HOT if so should i run a seperate wire to fuse accesory panel to stop from burnin up my wiper motor cuz it also aint working
bluntz420 is offline
post #2 of 9 (permalink) Old Aug 28th, 05, 08:12 AM
Re: riddle me this (hei dist)
If this is in a first gen, run a 12 gauge wire from the BAT terminal on the HEI to the IGN terminal on the fuseblock. The wires on the wiper motor were designed to power that and nothing else.
69 RS 355 Tremec 5-Speed 4.11's
12run is offline
post #3 of 9 (permalink) Old Aug 28th, 05, 09:29 AM Thread Starter
so i can run a 12g wire straight from fuse panel ing to the dist....do u think tappin into the wiper motor might have burnt it out since its gettin hot??
post #4 of 9 (permalink) Old Aug 28th, 05, 03:10 PM
Yes and yes.
12run is offline
post #5 of 9 (permalink) Old Aug 29th, 05, 06:03 PM
I don't think the ignition did anything to your wiper motor. The wiper motor gets power from the yellow wire and ground completes the circuit. Tapping into the yellow will not pull current through the wiper motor, but it will place additional load on the yellow wire.
dnult is offline
post #6 of 9 (permalink) Old Aug 30th, 05, 06:01 PM Thread Starter
but why does it get hot and now it doesnt work so am i to assume i need another or just dont get caught in the rain
post #7 of 9 (permalink) Old Aug 30th, 05, 08:21 PM
Check to make sure you're getting battery voltage at the yellow wire with the key on before you condemn the wiper motor. Also make sure your wiper linkage isn't jammed.
12run is offline
post #8 of 9 (permalink) Old Aug 31st, 05, 05:57 PM
Good question. Does it still get hot with the ignition disconnected?
I just thought of something though. The yellow wire to the wiper motor is only hot in the accessory position or run. So in crank, it will be dead. Could make for some rather frustrating starting problems.
Disconnect the ignition tap and put the key in the acc position. Then wait a couple minutes and see if the wiper motor gets hot.
dnult is offline
post #9 of 9 (permalink) Old Aug 31st, 05, 06:47 PM
Chris
Cool Re: riddle me this (hei dist)
To properly wire an HEI tap into the white igition (points resitsor) wire that goes to the points at the firewall block. Solder a tap as close as possible to the firewall block. This way you get a full 12 volts, Ignition fused hot and you can convert back to original easily if you need to.
Chris @ www.C-DPerformance.com
Motorhead62 is offline
HEI dist question georgia 69 Engine 5 Jan 7th, 05 12:59 PM
Will hei dist. fit in a 67? chorbs Engine 4 Jun 26th, 04 01:14 PM
HEI Dist. 12 V Source Emilio G Electrical & Wiring 6 Mar 7th, 03 04:56 PM
hei dist problem TWSLPS Engine 3 Dec 16th, 02 12:27 AM
Using original tach with HEI dist. orange/black69ss Electrical & Wiring 3 Mar 22nd, 02 06:17 AM
