Intermittent Starting Problems - Team Camaro Tech
post #1 of 9 (permalink) Old Aug 28th, 05, 12:28 AM Thread Starter
Usually, my car will start without problems. Sometimes, the starter will not engage. Relays will click but no start. When this occurs, a test light shows power to the purple starter lead when the key is turned, but the starter will not engage. When I jump the purple ignition wire at the starter to the battery, the starter will engage. Happens when hot and cold. I have replaced the solenoid, but I am still having the same problems. Can this be the starter itself, or am I missing something. Any advice? Mike
Mike67RS is offline
post #2 of 9 (permalink) Old Aug 28th, 05, 05:34 AM
Steven
Re: Intermittent Starting Problems
Mike, the fact that the car is starting when you jump the purple wire seem to imply tha you are experiencing a voltage drop. I would go back and re-check my cables and connections. I had a similar problem on my 67 Chevelle and it didn't go away until I replaced the pos battery cable.
sdtsdt is offline
post #3 of 9 (permalink) Old Aug 28th, 05, 11:23 AM Thread Starter
Thanks...Battery cables are new and connections are good. I changed the purple starter wire from the firewall to the starter. The under dash wires look good too. I will try to check the voltage at the starter.
Mike67RS is offline
post #4 of 9 (permalink) Old Aug 28th, 05, 12:41 PM
could be nuetral safety switch, or the ignition switch itself, too. Since we're talking 10 total feet of 12 guage wire plus 1 or 2 16 gauge fusible links, a lil voltage drop would be normal, and not present when you hit it with a screwdriver, so it could be dirty or corroded contacts in the solenoid, too.
post #5 of 9 (permalink) Old Aug 28th, 05, 01:44 PM Thread Starter
Thanks again. I bypassed the nuetral safety switch. I will go through all of contacts again, but they all appear to be clean. I think the consensus is a voltage drop problem, so I will go with that for now. Could it be the starter? As I said, I did replace the soloneoid.
Mike67RS is offline
post #6 of 9 (permalink) Old Aug 28th, 05, 03:49 PM
I had a similar problem. Everything seemed to be in order but sometimes it would just not start. Whithin seconds of boosting the battery it would fire. I tackled it by replacing the cables with repop spring rings, and a new 24-60 battery. I also had a problem with the barrel in the iginition switch so I replaced it.
Since then I have had no trouble with starting and I think it was just a weak battery after all.
My next step would have been to take it to my electronic shop to find out the fault. But so far it is solved.
I have owned 3 69 Z/28s: Garnet Red 30,000 mi unrestored.
Glacier Blue, documented Canadian Z
Rallye Green purchased new in 1969
1968 Camaro Coupe L30 275 horse. ]
Stewie is offline
post #7 of 9 (permalink) Old Aug 29th, 05, 12:52 AM
To check the entire starter circuit, electricity flows from the battery to the junction block, to the horn relay, to the bulkhead connector, to IGN switch, to neutral safety switch, to the starter "S" terminal. Check all connections and switches along this path. You may have a bad connection or high resistance in a switch.
Greg U
undee72Z is offline
post #8 of 9 (permalink) Old Aug 29th, 05, 01:15 AM
At this point I positively refuse to even attempt to crank a chevy small block with anything less than a 2 GA main positive and ground wire. Have had it with everything else. If everythng seems fine otherwise, the starter could simply have a high resistance spot where brushes hit. This will cause a voltage drop across whole ckt. This will be intermittent. But the odds against this being the problem are tremendous
You seem to have mentioned all else, but while working on it, put that new 2 gauge Battery and ground cable to use. Check and make sure the several grounds are also tight. I usually run a 2 gauge grd to block and with 4 to chassis. I also include the normal chassis ground wires that show stock, and run a second fused 4 ga bat cable to the inside for aux- radio's, amps and such. You could use your already new wires anyway?? Just for different purposes?
All this will save the next starter a huge amount of overwork and it'll last three times as long.
William van Hulst is offline
post #9 of 9 (permalink) Old Aug 30th, 05, 12:18 AM Thread Starter
Undee, I appreciate the tips on the layout of the electrical system, this will definitely help. I am leaning towards a starter problem since I recently assembled the car and al connections looked good then. Can the starter be removed as tested? Thanks again, Mike
Mike67RS is offline
89 Camaro RS -Starting Problems Tony T Troubleshooting 3 Nov 29th, 07 09:21 PM
starting problems DL Engine 4 Jul 13th, 04 03:31 PM
Starting problems lapookh Troubleshooting 2 May 11th, 04 04:45 PM
'97 camaro intermittent starting problem cajunbedbug Troubleshooting 1 Apr 17th, 03 01:47 AM
'73 starting problems Uni Troubleshooting 2 Mar 18th, 99 04:26 AM
