fan switch? - Team Camaro Tech
post #1 of 2 (permalink) Old Aug 28th, 05, 11:32 PM Thread Starter
Question fan switch?
hey guys i need some help with hooking up a switch for my electric fan. i have a painless harness in the car and they have a wire for the fan that goes to the fan switch but i dont know how im spose to hook up the switch. also wut kind of thermostat switch are you guys using so the fan will come on automatically. wut i want to happen is that the fan will come on automatically but also have a manual overide in the case of a failure.
thanx Nick
68 camaro, 350, comp cams xe262, hooker super comp headers, torque thrust II's, its a work in progress
NDubs68 is offline
post #2 of 2 (permalink) Old Aug 29th, 05, 01:25 AM
Re: fan switch?
Painless sells the part(s) you need. Check with them, you may only need to purchase the switch that looks like a temp sensor and threads into the intake or block. They sell a kit for the purpose with a relay, switch and breaker. Complete with diagram. I dont know how much of this came in your basic harness to begin with. Only contacting them or going over their diagrams will answer those questions.
I can't see them having any wiring in your new harness for this purpose unless they knew you were going to go to an electric fan. Your stock motor setup, thus the wiring harness, would not have had a need for any of this in original mode. Odds are you should get whole kit.
If I were to do another one, I would use a temp switch and a relay and call it a day. But since you are completely "painless" you ought to stay with their program to save future headaches.
William van Hulst is offline
'69 heat/air fan control switch/ Vintage Air 82Vettrin Heating & Cooling 5 Aug 29th, 05 05:09 PM
99 Wiring Diagram Power Door Lock DONZIGW Electrical & Wiring 1 Aug 16th, 05 11:59 PM
Electric Fan Wiring scalise Electrical & Wiring 1 Aug 14th, 05 03:01 PM
68 vacuum headlights Opening but not closing AAAAGGGG!!! ray moore Electrical & Wiring 11 Jul 7th, 05 05:01 PM
Wiper switch grounding, heads up TC Codi Electrical & Wiring 0 Jul 5th, 05 10:29 AM
