What is this buzzer that won't turn off? - Team Camaro Tech
post #1 of 2 (permalink) Old Sep 1st, 05, 04:16 PM Thread Starter
Cool What is this buzzer that won't turn off?
I've got a 93 v6 camaro and when I turn the engine off, pull out the key and then open the door a buzzer in the dash will come on. Now before you say "duh" its not the buzzer for my headlights or door ajar! Its not a "ding ding ding" sound that you normally get with the door open or the key in the ignition, or with your headlights on. Its a "buzzing" that stays on until I turn the key back to ON or START. But the second I turn that key back off the buzzer comes back. The buzzer will stay on in ACC and OFF all the time until the battery actually dies. I've pulled just about every fuse under the dash trying to isolate what circuit its on, but the buzzer stays on regardless of what fuse I pull. Anyone know what is causing this/how to eliminate it? Or atleast where the speaker is so I can cut the wire and stop draining my battery!
Subtlesustain is offline
post #2 of 2 (permalink) Old Sep 2nd, 05, 04:30 AM
Re: What is this buzzer that won't turn off?
Have you read the Operator's Manual for any suggestions?
Rear hatch not quite closed all the way?
What is this buzzer that won't turn off? Subtlesustain Troubleshooting 2 Sep 4th, 05 12:41 AM
Turn Signal Problem rookie68camaro Electrical & Wiring 2 Mar 20th, 05 04:28 AM
Front turn signal/parking lamp problem elcamino72 Electrical & Wiring 1 May 19th, 02 07:23 AM
BRAKE lights OUT when USING THE TURN SIGNALS KED67 Electrical & Wiring 5 Jun 26th, 01 04:40 PM
Tail Light Short & Turn Signal Switch KED67 Electrical & Wiring 3 Jun 25th, 01 09:40 AM
