68 Wiper ?????? - Team Camaro Tech
post #1 of 5 (permalink) Old Sep 3rd, 05, 08:16 PM Thread Starter
Unhappy 68 Wiper ??????
68 Camaro, Windshield wipers quit working, Nothing happens on slow or high speed, however when I depresss the switch, for the washers (no pump on wiper motor) the wipers work. So here I am in a rainstorm gripping the wheel between my teeth, depressing the wiper switch with my left hand and doing the manual windshield defrost wipe with my right hand. Just can't take too many more rain showers...
Has any one come across this????
What did you find????
thanks guys.
Rob.Canada is offline
post #2 of 5 (permalink) Old Sep 4th, 05, 08:42 AM
67 Camaros Rock
Joe Harrison's Avatar
Re: 68 Wiper ??????
Same problem, mine was a bad wiper switch.
Joe
-Mark Donahue
My 67 Camaro Time Line
Joe Harrison is offline
post #3 of 5 (permalink) Old Sep 9th, 05, 07:34 AM Thread Starter
Thumbs up Re: 68 Wiper ??????
Thanks Joe,
Goods place to start
Figure I might dig into it this weekend,
Rob
post #4 of 5 (permalink) Old Sep 9th, 05, 11:29 AM
Re: 68 Wiper ??????
The wiper motor gets 12V from the yellow wire. The wiper switch grounds the other wires to activate the motor. You might get our your volt meter and see if you have 12V on the other wires with the switch off and ensure ground is applied when the switch is in various positions. That should isolate the switch, wiring, and motor.
dnult is offline
post #5 of 5 (permalink) Old Sep 9th, 05, 04:37 PM
JohnZ's Avatar
Re: 68 Wiper ??????
Also make sure the copper strap that grounds the motor baseplate to the firewall at the upper mounting grommet is intact.
JohnZ
CRG
JohnZ is offline
Windshield Wiper Pressure Seakane Camaro Tech 13 Jun 13th, 05 12:04 PM
Help with wiper arm removal Obxhokie Camaro Tech 22 May 17th, 05 06:27 PM
Wiper Switch Question mjm7496 Electrical & Wiring 6 Apr 5th, 05 11:41 AM
windshield wiper motor does not work hobackriver Electrical & Wiring 5 Jul 17th, 03 05:52 AM
Calling all wiper arms! coach420 Body Shop 17 Jun 19th, 02 08:00 AM
