Circuit with two in-line fuses - Team Camaro Tech
post #1 of 5 (permalink) Old Sep 10th, 05, 11:39 AM Thread Starter
On my ''68'' by the voltage regulator is a ciccuit with two in-line fuses. It comes out of the harness a 10 guage red wire going into the first fuse it comes out an orange 16 guage wire about 5 inches long that goes into the second fuse and comes out a black with white stripe 16 guage wire that loops back into the harness. I can't find it in any of the wiring diagrams that I have, but I believe it's for the ammeter guage. My question is why would they have to use two fuses in series in one leg of a circuit? Thanks for any information, RonM.
RonM is offline
post #2 of 5 (permalink) Old Sep 10th, 05, 11:50 AM
Re: Circuit with two in-line fuses
It sounds like you are talking about the fusible links that normally attach to the horn relay. The inch long black plastic things are actually splices, not fuses. Here's a pic of the harness on a stock 68, with the tape removed. This car does not have factory guages or A/C, if it did, the wires would attach to the horn relay screws.
post #3 of 5 (permalink) Old Sep 10th, 05, 01:12 PM Thread Starter
JimM- Thanks for clearing that up for me, I always thought they were fuses. That leads me to another question, I have two other front lighting harnesses for spare parts they both have the two splices like the harness in your picture. The harness in my car also has the same two splices in addition to the the two splices I mentioned before. My question is were those splices only used by GM because it all looks factory and why would they take the horn relay out of the circuit? Thanks for any help, RonM.
RonM is offline
post #4 of 5 (permalink) Old Sep 10th, 05, 03:19 PM
I'm not sure why anyone would remove the horn relay, Ron, gues they didn't need a horn? but even then it would make sense to keep it for it's function as a junction block in the power feed system.
Those splices are factory, for the fusible links. The fusible links are just a short peice of lighter guage wire, desinged to burn up in case of an overload. In the pic I posted you can see 2 of them. The black one with the red wire attached is the main feed to the fuebox, the whole car runs off that one wire. The orange one in the regulator connector is the reg's "sensing wire", what it check toi monitor system voltage, the link ensures that a shorted regulator can't take out the entire system. If you had options such as A/C, power windows, or a power convertible top, the harness for those systems would pick up power from the horn relay, and some of those may have been protected by fusible links.
I've never actually seen the wiring on a factory guage car, but the ammeter is really a millvolt meter, it reads the voltage drop across the wire running from the main splice (silver thing where 4 red wires connect together in the pic) to the battery. The wires for that gauge would attach to the horn relay and to the little junction block on the rad support behind the battery.
post #5 of 5 (permalink) Old Sep 10th, 05, 05:07 PM Thread Starter
Jim I should have worded my question differently, I didn't mean they took the horn relay out of the car, I meant they took the horn relay out of the ammeter circuit. I see on the wiring diagram the black and white wire for the ammeter comes out of the terminal block on the firewall and splices into an orange fusible link and then connects to the horn relay. On my car the orange fusible link splices to another 10 guage red wire identical to the one going to the voltage regulator. There is an additional red 10 guage wire on my car that the wiring diagram doesn't show. There is a hood light on my car that connects to the horn relay, maybe that is the reason for the additional wire. Anyway thanks for your help, RonM.
RonM is offline
Drawbacks to large fuel line? 69Nova Performance 37 May 15th, 05 12:47 PM
Fuel Pump Line Fitting?? 67 Convertible Engine 4 Apr 20th, 05 05:46 AM
Fuel Line for Edelbrock Carb? JimM Engine 1 Oct 23rd, 04 07:37 AM
Steel vs. Rubber fuel line englemac Engine 6 Oct 15th, 01 09:18 PM
Can I convert my 1/4 vent/return line into a 14psi return line for TBI unit??? snflupigus Tech 2000 3 Jun 13th, 01 04:57 PM
