amp gauge dropping??? - Team Camaro Tech
post #1 of 3 (permalink) Old Sep 10th, 05, 08:57 PM Thread Starter
I bought a 68 camaro about a month ago, and have had this problem since day one. When no electrical components are on the amp meter is straight up (what I'd consider about normal). However, when I back out of the driveway and touch the brake pedal, the meter drops all the way down to "0". I let my foot off the brake and it goes back up. It also drops when I turn on the headlights, or when the stereo is on.
The car has sat for about a week in between driving it, and I've driven at one time for about 1.5 hours which shows the battery is maintaing a charge.
I am just trying to determine why the amp meter moves so much, and if the problem lies with the guage, alternator, or how it was wired.
I tried a search, but couldn't any thing in past threads.
Thanks for the help!
Greg
Gregs68U-U is offline
post #2 of 3 (permalink) Old Sep 11th, 05, 03:48 AM
Re: amp gauge dropping???
What kind of amp gauge, factory or aftermarket? Its moving because of voltage drop. If its a factory gauge wired correctly, it shouldn't move much, it only shows the battery's charging rate. If its a aftermarket gauge, depending on how its wired, it may show all of the cars current draw. Would need to know type of gauge and how its wired to give a better answer.
Greg U
undee72Z is offline
post #3 of 3 (permalink) Old Sep 12th, 05, 08:13 PM Thread Starter
The gauge is a console gauge, similar to what you'd buy from say Ricks as an OEM replacement console gauge. I am not sure on the exact brand, and I will have to check out the wiring. What am I looking for in the way of how its wired??
Greg
OER Temperature Gauge Pegged Hot hairboy Electrical & Wiring 0 Jul 26th, 05 07:39 AM
No Power To Amp Gauge 68 rs z28 Electrical & Wiring 5 Apr 29th, 05 05:24 PM
Another Fuel Gauge problem sgaylord Electrical & Wiring 7 Feb 4th, 03 12:11 PM
fuel gauge reads over full... mike brown Troubleshooting 10 Aug 4th, 02 09:29 AM
What's required to put an in dash tach in a 69 non tach car? SolidLifters Tech 2002 6 Mar 6th, 02 09:45 AM
