alternator whine - Team Camaro Tech
post #1 of 14 (permalink) Old Sep 11th, 05, 04:21 PM Thread Starter
Steven
stamatisg1977's Avatar
alternator whine
hey
is it normal for the powermaster 140 amp alternator to make a whining noise while driving or revving the engine?
stamatisg1977 is offline
post #2 of 14 (permalink) Old Sep 11th, 05, 05:54 PM
Rex
Re: alternator whine
make sure your belt is not to tight.
69 x-11..LS1, 420.88 horse to the tires,750 Holley Ultra DP, Torquer V2, darksides headers, PRC heads, 10.8:1 compression, forged bottom end, 5 speed. 2008 King Ranch F150 4x4.
trex70 is offline
post #3 of 14 (permalink) Old Sep 11th, 05, 05:57 PM Thread Starter
Steven
what is a good rule of thumb for proper tensioning?
post #4 of 14 (permalink) Old Sep 11th, 05, 06:07 PM
Harry
dawg's Avatar
1 inch of play at longest run.
you could have a bad bearing aswell
434 stroker
US Navy retired
dawg is offline
post #5 of 14 (permalink) Old Sep 11th, 05, 07:38 PM Thread Starter
Steven
i dont think its the bearing
the altenator is only been on the car for one day and hardly driven
post #6 of 14 (permalink) Old Sep 12th, 05, 04:49 PM
Rex
I have a powermaster alt and had to have it rebuilt within 3 days. I did not want to send it back, take to long, it cost me 30 bucks to rebuild.
trex70 is offline
post #7 of 14 (permalink) Old Sep 12th, 05, 05:52 PM
Harry
dawg's Avatar
just because its new doesnt mean its good?
434 stroker
US Navy retired
dawg is offline
post #8 of 14 (permalink) Old Sep 12th, 05, 06:30 PM
ZZ_430's Avatar
"the altenator is only been on the car for one day and hardly driven"
If the battery was low, it's normal for some "whine" while charging.
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #9 of 14 (permalink) Old Sep 12th, 05, 08:46 PM
Just because alternators are new most certainly doesnt mean they are good. In fact I wouldnt bet on it. I've been though many 'new' (yes, susposedly compleatly NEW) alternators that die within a few months; due to bearings; bad windings, etc...
Ford by far makes the best alternators; but I'm not bragging
Riccbhard is offline
post #10 of 14 (permalink) Old Sep 17th, 05, 11:11 AM Thread Starter
Steven
is it normal for the brushes to make the noise?
the alternator otherwise is functioning perfectly
post #11 of 14 (permalink) Old Sep 17th, 05, 11:22 AM
Harry
dawg's Avatar
no if they are really loud then something is wrong.
they are graphite and wear in about 5 mins of run time.
but I NEVER heard of bad brushes in a long while.
chances are the bearing is what you hear but you refuse to concider it ?
bad or dry bearings make whining squeeling noise.
its the only part that it can be.
BUT its new so it cant be it?
if your so unsure take it to a shop to have them diagnose it.
434 stroker
US Navy retired
dawg is offline
post #12 of 14 (permalink) Old Sep 17th, 05, 05:37 PM
Unlike a DC motor, an alternator has two solid commutators for the brushes to ride against. So you won't get the brush whine you would out of a DC motor with a segmented commutator. I concur with the others - most likely bearings. Could also be a loose mounting bolt, too tight on the belt, or acoustical noise from high charging currents. In the later case, it should quiet down a few minutes after start when the battery recovers.
dnult is offline
post #13 of 14 (permalink) Old Sep 17th, 05, 05:42 PM
if you're worried, take it apart and see, only 4 screws to get it open.
post #14 of 14 (permalink) Old Sep 17th, 05, 10:55 PM
Mist a little water on the belt while it is running and see if the noise changes. If it changes it's the belt.
69cama is offline
