Voltmeter, where is the best place to connect under the hood? - Team Camaro Tech
post #1 of 5 (permalink) Old Sep 13th, 05, 12:13 PM Thread Starter
Hi guys,
I just bought new batterty terminals with a bult in volt meter.
The wires are real short. Where is the best place (Under the hood) to connect??
Thanks in advance,
Nick
1967rsss350 is offline
post #2 of 5 (permalink) Old Sep 13th, 05, 07:32 PM
Larry
Re: Voltmeter, where is the best place to connect under the hood?
If you want the gauge to only work when the ignition is on, the only place I can think of off the top of my head is the yellow wire going to the wiper motor. Everything else under the hood is either fulltime power or has power when a specific component is operated.
Larry
69-er is offline
post #3 of 5 (permalink) Old Sep 13th, 05, 07:36 PM
69-r brings up a good point. Might as well connect under the dash. If the dash voltage is low you can presume everything else is. So the meter would still give you valuable feedback.
dnult is offline
post #4 of 5 (permalink) Old Sep 14th, 05, 07:50 AM Thread Starter
Thanks guys.
By the way, I have an electronic ignition MSD box & mallory coil. Is it ok to attach it to one of those?
post #5 of 5 (permalink) Old Sep 14th, 05, 04:28 PM
Certainly. I presume your ignition box is connected to an IGN source. This presumes your IGN feed is not a resistor wire. It also presumes that if you have a ballast resistor that the guage connects to the 12v side. Other than those two caveats, the ignition system is a great place to connect.
dnult is offline
Door adjustment jsouthco68camaro Body Shop 9 Mar 7th, 05 06:46 AM
How do I tell an NOS hood from a repro? Barefoot Dave Body Shop 1 Oct 13th, 04 01:32 PM
1968 door alignment Steve W Body Shop 5 Sep 9th, 03 05:15 PM
Trunk Lid Fit Problem RPOL72 Body Shop 8 Aug 27th, 03 02:45 AM
Harwood Cowl Hood Installation ChevyCam Body Shop 1 Jul 10th, 02 04:20 AM
