87 iroc cant find temperature switch - Team Camaro Tech
post #1 of 4 (permalink) Old Sep 16th, 05, 12:39 AM Thread Starter
Hi,
I have an 87 z28 iroc camaro and the temperature gauge recently became pinned in the highest temp. position. I think the temperature switch or temperature sending unit is the problem. Could you tell me where this is located on my car it has 305 t.p.i. with an automatic.My chiltons manual says it is located on the thermostate elbow but not on my car. Any advice on this matter would be greatly appreciated. Thanks g.
chevyone is offline
post #2 of 4 (permalink) Old Sep 16th, 05, 04:40 AM
Re: 87 iroc cant find temperature switch
Try drvr side cylinder head between #1 & #3 cylinder exhaust ports.
If you measure the resistance of the sending unit with the engine cold, center lead of sending unit to ground, it will read a high resistance, ie, 5K or more. As it warms up, it will read less than 200 ohms.
You also might try banging the dash with your fist to "unstick" the needle. With key off, the needle may go back to cold. With sending unit unplgged, and key to on, needle should go to cold. Hit dash at black square!
post #3 of 4 (permalink) Old Sep 16th, 05, 12:55 PM Thread Starter
Thanks I will look there.The tips will be helpful i am sure. g
chevyone is offline
post #4 of 4 (permalink) Old Sep 28th, 05, 03:25 PM Thread Starter
Thank you the temperature switch was there. I really appreciate your help, you saved me alot of trouble.
Thanks again G.
chevyone is offline
Column Shift Neutral Safety Switch Numbers.. dschribs Tag Team 3 Jan 3rd, 05 02:07 PM
67 rs headlights 19673L4P Electrical & Wiring 6 Jun 23rd, 04 02:55 PM
temperature sender or switch? Pildor Electrical & Wiring 1 Mar 23rd, 04 08:06 AM
Wiper Switch...Good or Bad? choptop Electrical & Wiring 4 Jun 13th, 01 09:40 AM
