Turn Signals inop - Team Camaro Tech
post #1 of 4 (permalink) Old Sep 16th, 05, 05:13 AM Thread Starter
Turn Signals inop
Dumb question probably, but I'm stuck ...
Turn signals on my 99 Camaro stopped working ... get no turn light on instrument panel or exterior. HOWEVER, emergency flashers work fine (light up and flash). Fuse appears good, bulbs are fine. Any ideas?
Roy George is offline
post #2 of 4 (permalink) Old Sep 16th, 05, 02:23 PM
Re: Turn Signals inop
I'm not sure about the '99, but the older models used two flashers. One for the emergency flashers and one for the turn signals. The emergency flasher was on the fuseblock and the turn signal flasher was up under the dash. It may still be that way. Worth looking into.
69 RS 355 Tremec 5-Speed 4.11's
12run is offline
post #3 of 4 (permalink) Old Sep 17th, 05, 05:40 AM Thread Starter
Thank you 12Run ... that was the problem.
post #4 of 4 (permalink) Old Sep 17th, 05, 09:57 AM
Happy to help.
12run is offline
Littering and Turn Signals TJS69 Bench Racing 12 Sep 7th, 05 05:44 PM
turn signals not working kool Electrical & Wiring 1 Apr 18th, 05 05:51 PM
Can't figure out turn signals!! scalise Electrical & Wiring 1 Feb 10th, 02 07:56 AM
BRAKE lights OUT when USING THE TURN SIGNALS KED67 Electrical & Wiring 5 Jun 26th, 01 04:40 PM
No Front Turn signals? JC69RSZ28 Troubleshooting 1 Nov 13th, 00 02:51 PM
