Highbeam switch is dead. How do I fix it? - Team Camaro Tech
post #1 of 3 (permalink) Old Sep 26th, 05, 01:37 PM Thread Starter
The highbeam switch is located on the turn-signal-lever. When I pull back on the lever I feel no click and the highbeams don't come on. The highbeam switch seems to be busted.
But how do I get to it? Do I have to take apart the steering column? The parts guys at the Chevy house said there was a rod that went to an easily accessable switch, but I don't see anything like that. My Hayes manual doesn't have this in it either (Up a creek without a paddle.)
Anyone here ever replace the higbeam switch? Any tips on how to access it?
1998 Camaro Z28, automatic, 5.7L, Coupe.
samualt is offline
post #2 of 3 (permalink) Old Sep 29th, 05, 10:27 AM Thread Starter
Re: Highbeam switch is dead. How do I fix it?
The switch is underneath the dash above the kick panel. Then you must pull down the other plastic panel that covers the computer plug, very easy. There is a rod that hugs the steering column and goes back to the actual switch. There are two little 5/16 bolts that hold the bracket in place. The bolts are a little hard to get to and facing up. I found the switch, moved it forward a little, and now it all works. The switch is not in the column.
samualt is offline
post #3 of 3 (permalink) Old Sep 29th, 05, 11:55 AM
Vintage 68's Avatar
Thumbs up Re: Highbeam switch is dead. How do I fix it?
Sam;
Thanks for the feed-back on that
This forum mainly deals with the 1st Gen. Camaros and I'm sure that's why you didn't get many takers on your post.
MAny of us do however have newer Camaro's & other cars and help many friends and neighbors maintain theirs, so this info will no doubt come in very handy some day
1968 Convertible
Some trucks
Vintage 68 is offline
99 Wiring Diagram Power Door Lock DONZIGW Electrical & Wiring 1 Aug 16th, 05 11:59 PM
68 vacuum headlights Opening but not closing AAAAGGGG!!! ray moore Electrical & Wiring 11 Jul 7th, 05 05:01 PM
Wiper switch grounding, heads up TC Codi Electrical & Wiring 0 Jul 5th, 05 10:29 AM
Wiper Switch Question mjm7496 Electrical & Wiring 6 Apr 5th, 05 11:41 AM
67 rs headlights 19673L4P Electrical & Wiring 6 Jun 23rd, 04 02:55 PM
