Charging System - Team Camaro Tech
post #1 of 2 (permalink) Old Sep 29th, 05, 06:35 PM Thread Starter
Jonny
Charging System
A pirate walks into a bar with a steering wheel sticking out of his pants...the bartender asks, "Ya know, you have a steering wheel sticking out of your pants". The pirate replies, "Yarrrr, I know. She's drivin' me nuts!!"
My charging system is drivin' me nuts!!
Was having no charge at batt. Changed out the voltage reg and all looks ok. Except GEN light is dim (not bright) with engine on. Voltage at batt is 13.5 or 14. Good there. What could this light be from? Pretty sure I have good grounds. Headlights work great.
Performed KOEO, KOER test at reg harness, unplugged:
KOEO
#1 Slight voltage
#2 Zero
#3 12V
#4 12V??? Should be slight voltage.
KOER
#1 Zero??? Should be 9-12V
#2 Not sure what >3.2V means
#3 12V
#4 12V
Also, I downloaded 69-ers color wiring diagrams. Great job, 69-er!! THANK YOU! Under charging system, at alternator, should white go to R and dk blue go to F, instead of what is shown (other way around)?? This is how mine is now set up, and the only way it is currently charging the batt. Thanks!!
The Beerboy is offline
post #2 of 2 (permalink) Old Sep 29th, 05, 07:14 PM
Larry
Re: Charging System
You are absolutely correct. Thanks for the feedback! The corrected diagram is now available for viewing.
69-er is offline
How do I test my charging system? Darin Imbriaco Electrical & Wiring 2 Sep 3rd, 05 08:32 PM
89 RS Charging system issue Riccbhard Engine 5 Jul 1st, 05 02:09 PM
69 Camaro Charging System ldrisner Electrical & Wiring 4 Mar 29th, 05 05:20 AM
Charging System Confusion fdny37 Electrical & Wiring 2 Feb 26th, 05 02:46 PM
Charging System / Alternator Trouble Z28 Mark @home Electrical & Wiring 12 Jan 15th, 03 01:22 AM
