engine bay wiring - Team Camaro Tech
post #1 of 6 (permalink) Old Oct 2nd, 05, 11:14 AM Thread Starter
Question engine bay wiring
just bought a 68ss it had original wiring in very bad shape so i bought a painless harness for it is there anything i should be aware of with this new harness cause it doesnt have fuseible links on it like the original all the wiring is ran and have some components hooked up but im stumbiling a bit now that im to the engine compartment
longhorn is offline
post #2 of 6 (permalink) Old Oct 2nd, 05, 11:24 AM
Harry
dawg's Avatar
Re: engine bay wiring
send it back! No really
nothing but problems with painless wiring.
use 1 of these.
http://www.madelectrical.com/index.shtml
http://www.americanautowire.com/
do a search in the forums about painless wiring installs
434 stroker
US Navy retired
dawg is offline
post #3 of 6 (permalink) Old Oct 3rd, 05, 06:12 AM
Is the engine you have in it the original, or is it a replacement? Reason I ask is because if the engine you have is not exactly identical to the origional one, you can be sure to run into problems.
When you buy an American car, you provide work for a man and his family for three months. -Jay Leno
garfield is offline
post #4 of 6 (permalink) Old Oct 3rd, 05, 09:41 AM
Wes
I've had very good luck cleaning up the original wiring if it's at all usable. You need some good wiring tools, connectors, and colored braided wire, all of which are available at Home Depot. The heat shrink tubes are great for splices, and Rick's sells the origianal wiring tape for about $10 to keep things looking original.
Also, get a $20 volt-meter (which can also test continuity and resistance) which will save hours on diagnotics if you run into probs (and you will).
Good luck!
Straight-line-69 is offline
post #5 of 6 (permalink) Old Oct 5th, 05, 07:37 PM Thread Starter
not original i think its a 73 350
longhorn is offline
post #6 of 6 (permalink) Old Oct 5th, 05, 08:42 PM
73 would wire up pretty darned close to a 69. Do a search in electrical for "color wiring diagram" Another member made full color pdf's of the whole car's wiring broken down into separate systems. they are very easy to follow.
WHY KEEP ENGINE RPMS under 7000rpm grumpyvette Performance 50 Oct 4th, 05 10:39 AM
What engine is this inside of my 67 Camaro?? camaro_town Tag Team 3 Apr 23rd, 04 06:14 PM
Update on Golens Engine 383!! wildkatz Tech 2001 23 Dec 7th, 01 10:49 AM
is 220 bad? jvolk81 Tech 2001 15 Oct 26th, 01 03:11 PM
New Engine Break-IN Procedure (GM crate motor) sr71bb Engine 12 Dec 19th, 00 09:35 AM
