Painless wiring TPI swap ECM Problems - Team Camaro Tech
post #1 of 7 (permalink) Old Dec 30th, 05, 09:54 PM Thread Starter
Question Painless wiring TPI swap ECM Problems
I swapped an 84 5.0 4bbl over to an 88 TPI with a "Painless Wiring" Harness stock number 60102. The new aftermarket harness has two fuses next to the ECM location. I have confirmed power to the harness but the fuses don't have power to them. Is it possible the computer is faulty? The body and motor seem to be grounded well so I do not believe that to be the cause. Anyone familiar with this aftermarket harness have any ideas of the problem? I'm in a jam here! Thanks
After further investigation I found that I had misplaced the red wire from my harness to the small terminal on the starter instead of the large terminal. That provided power to the 30 amp fuse but not the 15 amp.
5speed is offline
post #2 of 7 (permalink) Old Dec 31st, 05, 03:37 PM Thread Starter
Re: Painless wiring TPI swap ECM Problems
Also I'm trying to find the start wire from the ignition switch. I have wiring diagrams, but I cant seem to find it. Am I correct in thinking that this is a wire that will only be hot in the start position? And if so it should light up with a test light when you crank the key over if you had a lead plugged in on that wire? I have the wire that comes off the starter solonoid, and if I connect it to a power source the starter will crank, and so I need to find the correct wire from the ignition switch to splice my wire into. It seems pretty simple, but I've spent hours under the dash and at the bulkhead connector trying to find it and still no luck.
5speed is offline
post #3 of 7 (permalink) Old Dec 31st, 05, 08:48 PM
Fifteen amp fuse should have IGN on source power?
Start power is purple wire to solenoid only in START position.
post #4 of 7 (permalink) Old Jan 1st, 06, 10:12 AM Thread Starter
Thanks Evertt#2390. The 15amp fuse does power up when I turn on the ignition. My wiring diagrams show the purple wire just like you said as the start wire. I just cant find it. I spent a few hours alone yesterday with the seats removed, upside down with a test light searching for the start wire. I would probe a wire and turn the key but I could never get the light to come on unless I probed a constant positive wire somewhere. I guess my question would be... Am I looking in the wrong place under the steering column, by the fuse box, and at the bulkhead connector? Does the dash need to be removed to locate the wire? Maybe someone knows an easy way to find it. Thanks again for all your help.
5speed is offline
post #5 of 7 (permalink) Old Jan 1st, 06, 08:29 PM
I believe the purple wire starts at the ignition switch, goes to the neutral safety switch at the trans selector, changes to purple/white and goes to the bulkhead connector. From there, goes across the engine side of firewall to the pass side, then drops down to the starter solenoid.
post #6 of 7 (permalink) Old Jan 6th, 06, 10:46 AM Thread Starter
Thanks! After replacing a faulty neutral safety switch, things were making sense again. This tech section really makes this site something special, It's great that you can get some help here, and all the fellow Camaro owners out there can chat here. Thanks again techs, I'll be sure to send new members your way.
5speed is offline
post #7 of 7 (permalink) Old Jan 6th, 06, 01:37 PM
BonzoHansen's Avatar
Yes, the tech help here is great. I learn daily.
For what you are doing, you may want to peruse the forums & info at thirdgen.org A lot of third gen info and swap info there. Good luck.
TC Member #13
BonzoHansen is offline
