RS Wiper Motor/Pump Wiring Detail Question - Team Camaro Tech
post #1 of 2 (permalink) Old Jan 1st, 06, 09:39 AM Thread Starter
Russ
Question RS Wiper Motor/Pump Wiring Detail Question
I'm sure this subject has been beat to death in the past, but I can't seem to find the exact answer to my question in the archives.
It would be greatly appreciated if someone could help me out on the connection points for the various wires on the '69 RS Wiper motor and pump. I've posted a picture with numbered terminals, would it be possible for color codes/routing locations of the wires from each terminal??
I've already labeled some that I "think" are accurate based on photos of other members rides on this site...
thanks much in advance.
Blown 69 RS Camaro
383 Small Block
Dyno: 578 Horse - 595 LB/Torque
Blown69RS is offline
post #2 of 2 (permalink) Old Jan 1st, 06, 10:22 AM
Kevin
KevinW's Avatar
Re: RS Wiper Motor/Pump Wiring Detail Question
Here is a test bench diagram I made up for 69. Has the wire colors on it.
On the RS soleniod, I have black (pump, top) going to bottom soleniod and black/brown stripe (pump, bottom) going to soleniod top. Not sure if it is factory, just they way it was when I pulled it off 20+ years ago. Picture in this thread. There is also a different lead on the pump side for the pump wire plug.
https://www.camaros.net/forums/showthread.php?t=70253
Kevin
KevinW is offline
