Butane Soldering Iron - Team Camaro Tech
post #1 of 3 (permalink) Old Jan 2nd, 06, 07:23 PM Thread Starter
Do any of you guys have one? Do you like it? I'm looking at getting one and wanted to hear some opinions.
Thanks.
steve
eville is offline
post #2 of 3 (permalink) Old Jan 2nd, 06, 10:01 PM
Russ
Re: Butane Soldering Iron
I bought the Wall Lenk LSP-180 a few months back. So far, no problems at all. If I recall, it's equivalent to a 35-180W traditional iron. The things I looked for to begin with are: has to be capable of soldering some larger gauge wire (8-10 AWG), additional add-on of a heat blower (for shrink wrap), easy push-button ignition, and definately refillable butane cartridges.
Some models use cells that must be purchased (no refills), some are so weak, they basically are useless except for the smallest solder point on a circuit board.
Blown 69 RS Camaro
383 Small Block
Dyno: 578 Horse - 595 LB/Torque
Blown69RS is offline
post #3 of 3 (permalink) Old Jan 3rd, 06, 05:42 AM
I have a weller pyropen jr. Don't recall what I paid for it, but it wasn't as cheap as many others out there. The reason I bought it was because it had better heat control for removing surface mount ICs. However the PP Jr. is now a sick puppy. Not sure what's wrong with it, but I can't keep the gas flowing any longer. Perhaps the regulator is plugging up. I know several guys that have a less expensive butane iron but I don't recall the brand. All I know is that it came in a plastic box and the iron is red. Seems they are still having good luck with theirs. I second the remark about a hot-air attachment. Don't buy a butane iron without it.
dnult is offline
