Electrical Basics - Team Camaro Tech
post #1 of 8 (permalink) Old Jan 7th, 06, 08:47 PM Thread Starter
Electrical Basics
You can find my Electical Basics articles here Electical Basics
post #2 of 8 (permalink) Old Nov 9th, 06, 05:58 PM Thread Starter
Re: Electrical Basics
This from CFunk regarding tail light sockets for 67 & 69's, might fir 69's too:
The manf. is CALTERM and the PN is 08562.
I picked it up from Advance Auto
post #3 of 8 (permalink) Old Aug 6th, 07, 11:58 PM
How do I get into your sticky on electrical trouble shooting? I have the same problem of a good battery going dead after installing an MSD like (new summit) CD ignition box.
Many thanks for your help in the past
smiller is offline
post #4 of 8 (permalink) Old Aug 8th, 07, 07:00 PM Thread Starter
Originally Posted by smiller View Post
Is that a hint?
I haven't written it yet.
What's up there is pretty good tho, if I do say so myself.
post #5 of 8 (permalink) Old Aug 26th, 07, 08:09 PM Thread Starter
one thing I just noticed on these diagrams is that, since they are circuit by circuit, it can be less than easy when trying to figure out an entire "hanress" as in locating And identifying cut and missing wires.
If you look at the B/H Connector (bulkhead connector) page, it clearly shows the color, gauge, circuit, and purpose of each wire in the engine and front lighting harnesses.
post #6 of 8 (permalink) Old Jul 30th, 08, 08:03 AM
Hey Jim, can I please get the password for your wiring diagrams? Finishing up my 69RS numbers matching everything and am down to the dash/console and interior. Thx!
jimlaughlin is offline
post #7 of 8 (permalink) Old Jun 6th, 09, 10:06 AM
Kevin
Any suggestions on the horn relay becoming a little too warm or "hot" if I could use that word ??? ... Once again, I am attempting to problem solve a steering wheel replacement back to original style ... I managed (by reading the posts) to remove it, remove the locking spring (after tool purchase), replace the turn signal canceling cam (everything else looked normal) so I began the installation ... Got down to missing parts which were problem solved by reading the posts ... Now I would like to hear the horns sound off ... I understand that they may not necessarily work (over time they stick or become malfunctioning), But then the horn relay was excessively hot so I replaced that and no change ... I tried disconnecting the horns, then the green wire from the horn relay, then taking the horn contacts back off ... Okay, it's all the same ... still a hot horn relay ... Any suggestions ? ... Kevin (kmg1969ss)
kmg1969ss is offline
post #8 of 8 (permalink) Old Jun 8th, 09, 09:25 AM
Kevin
Horn relay problem was solved ... See '69 horn questions for the resolution to this proposed question ...
Closed Thread
