head lights won't come on - Team Camaro Tech
post #1 of 15 (permalink) Old Jan 8th, 06, 05:11 AM Thread Starter
Question head lights won't come on
Help needed!!!! I have a 68 and was riding home the other night and the head lights went out. All side markers and the parking lights are still on. I turned the light switch off and then back on but still no head lights. Any suggestions as to where to start checking? Some one suggested the ground for the head lights may be the problem.
orange 68 is offline
post #2 of 15 (permalink) Old Jan 8th, 06, 08:18 AM
Larry
Re: head lights won't come on
Since the headlights have a ground for each lamp, it's doubtful that both the grounds went out simutaneously. The light switch or the dimmer switch is probably the culprit. I'd put my money on the dimmer switch. They take more abuse than the light switch.
Larry
69-er is offline
post #3 of 15 (permalink) Old Jan 8th, 06, 08:46 AM
I had that problem and it turned out to be the dimmer swith on the floor. Do the brights come on? It's an easy fix.
eville is offline
post #4 of 15 (permalink) Old Jan 8th, 06, 09:32 AM Thread Starter
I will have to check to see if the brights come on, Iwill post as soon as I can get out and check them out. Thanks
post #5 of 15 (permalink) Old Jan 8th, 06, 09:46 AM
Larry
Larry, I agree on the dimmer switch, but the 68's don't have a separate ground for each headlight. Both headlights ground thru a single wire attached to the engine side of the rad support, same screw as the regulator ground wire.
The parking lights and front markers are on a separate ground wire that attaches to the pass side headlight bracket.
post #6 of 15 (permalink) Old Jan 8th, 06, 09:52 AM
Larry
Oops! There I go again! I tend to group all 1st gen Camaros together and start refering to the 69 for problems with 67 and 68. I also refered to the 68 factory diagram, which matches the 69 in the number of headlight ground locations. Is this part of the diagram in error?
Larry
69-er is offline
post #7 of 15 (permalink) Old Jan 8th, 06, 10:01 AM
click's Avatar
bet its the dimmer switch too, pesky things get dirt and sand and the wires sometimes pulled away from a tight connection. Been there, done that.
click is offline
post #8 of 15 (permalink) Old Jan 8th, 06, 10:06 AM
My 68 rs/ss has a ground wire for both headlights on each side.
Hammer49 is offline
post #9 of 15 (permalink) Old Jan 8th, 06, 10:13 AM
Larry
You know, I just got done inspecting a 68 lighting harness, and I don't have any notes indicating that the grounds were different from the factory diagrams. Also the side markers grounds were tied into both the headlight connector grounds. Is yours that way too, Hammer?
Jim, are you able to look at an actual harness to verify this?
Larry
69-er is offline
post #10 of 15 (permalink) Old Jan 8th, 06, 10:14 AM
Larry
Looks my memory may be in error, so there I go again too.
Sorry for hijacking the post with this!
The 68 parking lights each have their own short ground wire, attaching to the adjacent headlight bracket, per the assy manual and virified on my car.
Both headlights have 2 black wires to the socket as shown in the diagram. Assuming (as shown in the diagram) that the second goes to the marker light.
post #11 of 15 (permalink) Old Jan 8th, 06, 10:18 AM
Larry
Thanks for checking this Jim. I want to be sure my 68 diagrams are going to be correct, if I ever get them done.
Larry
69-er is offline
post #12 of 15 (permalink) Old Jan 8th, 06, 02:05 PM Thread Starter
Thumbs up Re: head lights won't come on
Yopu guys are outstanding. I went out and turn on my lights ans they did nothing and then I pushed teh high/low beam switch and the lights came on. After a little inspecting, I think I still have the orginal dimmer switch from the way it looks and feels. I am surprised I haven't had problems before now. I will have to order a replacement. Thanks Again and this is one of the benefits from this great web site.
Thanks Again
post #13 of 15 (permalink) Old Jan 8th, 06, 02:07 PM
Larry
Great!!
You can get them at your local auto parts store. They're pretty common.
Larry
69-er is offline
post #14 of 15 (permalink) Old Jan 8th, 06, 02:30 PM
click's Avatar
while you are fussing with that, pull the wire connectors out of the plastic sleeve and clean them up with brass wire or brush and check wires for breaks or cuts. If all is good, shove the terminals back in but be sure you only do one at a time and get them in the same spots again. Its a dirty, sometimes wet place on the floor and prone to rust on the elec. connections there.
click is offline
post #15 of 15 (permalink) Old Jan 8th, 06, 02:47 PM
if they're really nasty, Napa can get the exact terminals, mine even had some in stock. Can't for the life of me remember where I left the reciept with the part #...
