Measuring Electricity - Team Camaro Tech
post #1 of 8 (permalink) Old Jan 8th, 06, 07:31 AM Thread Starter
sorry guys
post #2 of 8 (permalink) Old Jan 8th, 06, 07:13 PM
Re: Measuring Electricity
Jim, excellent work!
Let me add a little concerning the internal resistance of voltmeters.
If you are measuring voltage on very low current circuits such as electronic engine controls on modern vehicles, a voltmeter with an internal resistance (impedance) of at least 10 mega ohms is specified. I've never seen an analog voltmeter that meets this spec.
If the resistance of the voltmeter is not high enough, just taking the measurement can affect the voltage of the circuit enough to not only make the reading invalid, but can also affect the circuit to a point that the engine runs differently.
Just a word of warning to those using an analog meter to test sensors and such on their fuel injected vehicles.
Thanks Jim, keep up the good work.
red67camaro is offline
post #3 of 8 (permalink) Old Jan 8th, 06, 08:44 PM
Larry
Lookin' good Jim.
Can I add something too? Using a test light and maybe even an old analog voltmeter for cars that have computers could damage some of the sensitive circuits from the high ampearge draw of the light bulb. As far as any sensitive circuit is concerned, the bulb would be direct short to ground.
Larry
69-er is offline
post #4 of 8 (permalink) Old Jan 9th, 06, 06:13 AM Thread Starter
OK OK... I'll add a bit of a disclaimer regarding newer cars... itsa short peice and there is room.... Did they make any cars after 1969?
post #5 of 8 (permalink) Old Jan 9th, 06, 08:47 PM
Larry
You make a good point... Did they make any cars after 69?
But, seriously, we are talking about pre-computer cars 99% of the time. But, ya never know...
Larry
69-er is offline
post #6 of 8 (permalink) Old Jan 10th, 06, 03:20 AM
Good article, JimM. A DMM ( Digital MultiMeter) operator's tip.
When measuring resistance and the DMM shows a negative sign on the display along with a value, the negative sign is indicating to the operator the presence of voltage across the unit being measured.
The numeric value shown will not be the correct ohms value. The operator must isolate the component to get a correct ohms reading.
post #7 of 8 (permalink) Old Jan 10th, 06, 05:30 AM
Gold Member
Todd
Thumbs up Re: Measuring Electricity
JimM
Awesome job!
Al put him in for a raise!
Electrical section coming right along, Fluke meters are the best
for any electrical system but gosh do they get spendy.
Site's getting better all the time.
Todd
69Z
VI018DZ is offline
post #8 of 8 (permalink) Old Mar 3rd, 06, 09:29 PM
David Pozzi
davidpozzi's Avatar
Here is battery state of charge info:
STATE
OF
CHARGE ----VOLTS
100%---------12.66
75%----------12.45
50%----------12.24
25%----------12.06
0%-----------11.89
With engine running, you need to see 13.5 to 14.5 volts at the battery. If there is less than that, the altenator is not producing enough volts to fully charge the battery.
davidpozzi is offline
