Alternator Amp? - Team Camaro Tech
post #1 of 6 (permalink) Old Jan 8th, 06, 11:35 AM Thread Starter
ENP
Alternator Amp?
I am restoring my car. I plan on going with a 1-wire alternator. My question is what size of alternator do I need. Besides the factory electrical equipment I am using a electric fuel pump and electric radiator fan. I currently have a 100amp chrome alternator and red top optimum battery. Is this enough alternator for the job?
ENP is offline
post #2 of 6 (permalink) Old Jan 8th, 06, 08:16 PM
Re: Alternator Amp?
Probably so. Electric fans vary. They can pull as much as 80 Amps upon startup, but most will run steady at 20-40 amps depending on the fan. But it really depends on your alternator.
Many of the 100Amp alternators I am familiar with are the 12SI type - particularly the one wire type. They do a pretty good job, but their idle charge current rating isn't as good as say a CS130/140 alternator. That can be an issue if you're idling in traffic on a hot summer day, and your 100Amp alternator can't keep up with running the fans and other stuff. You'll need to get some specs on your alternator to know for sure.
Any reason why you chose a 1-wire? They are easy to hook up, but you give up some features you would get with a 3 wire setup. Examples are remote voltage sensing and GEN light.
dnult is offline
post #3 of 6 (permalink) Old Jan 8th, 06, 09:08 PM
Chris
Cool Re: Alternator Amp?
I would install a nice big 160-amp alternator. Electric fans pull alot of amps at idle and that is the toughest time for everything to work right and keep cool.
Check out this link:
http://www.motorcityreman.com/high-a...-mount-gm.html
Motorcityreman is my source for HP staters and alternators
1967 Chevelle 496BB/TH400/Dana-60 (Show and Go)
1967 El Camino 388SB/700R4/12-bolt posi (Daily Driver)
1967 C10 Short-Wide 496BB/TH400/12-bolt (The Shop Truck)
2008 Harley Davidson Dyna Low Rider
Chris @
Motorhead62 is offline
post #4 of 6 (permalink) Old Jan 9th, 06, 05:30 AM Thread Starter
ENP
Re: Alternator Amp?
The main reason for going with the 1-wire is the ease of installation. If I do go with the 1-wire hookup I will buy the factory fit alternator conversion harness. I still have the option of intalling my 1-wire alt with the factory 3-wire hook up. It has the "VR" plug in the back of the alternator. My camaro has the factory console gauges. Dnult, what do you mean by having the GEN light feature?
ENP is offline
post #5 of 6 (permalink) Old Jan 9th, 06, 06:42 AM
BonzoHansen's Avatar
Re: Alternator Amp?
I don't get the impression a 1-wire is the way to go in the street, especially with heavy amp loads (fans, etc.)
Read everything here first: http://www.madelectrical.com/
The easy way and electrical seldom work well together. And if the only big draw you have is fans & electric pump, I would think a 100-amp is more than enough, especially if the wiring is right. It seems to work fine for production cars.
Also look into better electric fan management, like the delta controller controller.
TC Member #13
BonzoHansen is offline
post #6 of 6 (permalink) Old Jan 9th, 06, 12:32 PM
Re: Alternator Amp?
Originally Posted by ENP
...Dnult, what do you mean by having the GEN light feature?
Using the CS-130 as a reference (others are similar) there is a brown wire that connects to the GEN lamp on the instrument panel. This line excites the regulator and provides a warning lamp if the alternator fails. With a one wire, you'll loose the GEN light.
Remote voltage sensing is the other feature. There is a red wire that can be connected to a remote location to ensure the voltage is regulated at that point. The horn relay is the most likely spot. This setup will ensure the relay bus-bar is regulated while the charge wire to the battery can be allowed to run at a slightly higher voltage. It helps keep the vehicle power constant while avoiding voltage drops in the wiring that would make the battery charge more slowly.
dnult is offline
