HEI Wiring hook up - Team Camaro Tech
post #1 of 3 (permalink) Old Jan 9th, 06, 05:02 AM Thread Starter
Question HEI Wiring hook up
Just got a HEI Dist. and I was hoping someone could tell me how to wire it up, what colors go where...Thanks
ce1967 is offline
post #2 of 3 (permalink) Old Jan 9th, 06, 12:56 PM
Re: HEI Wiring hook up
If you do a search you should find what you need. This installation has been covered many times.
69 RS 355 Tremec 5-Speed 4.11's
12run is offline
post #3 of 3 (permalink) Old Jan 10th, 06, 03:05 AM
Either
1. Locate the OE cloth covered wire back to the firewall connector and snip it with a 2 inch pigtail remaining and either butt connect or solder a #12 AWG lead from the connector to the HEI distributor, or
2. Run a new #12 AWG lead from the fusebox connected to an IGN switched terminal.
Hook the power lead to BAT terminal or the right front terminal, furthest away from the body. Hook tach wire to left front terminal. Hook & snap the module connector to the terminals closet to the body.
The distributor cap may be embossed with the names of the terminals. Install a good set of plug wires. I find GMPP wires work very well on my truck.
